20 Most Recent Velodyne CHT-12 Subwoofer Questions & Answers
0answers
0answers
0answers
If you are looking at
Anything coming into a device is an INPUT. OUTs always connect to INs.
Register and download the manual for free at audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/velodyne_acoustics/cht-12.html
6/25/2011 10:27:14 PM • Velodyne CHT-12... • Answered on Jun 25, 2011
Is there a picture on
Yup, in its manual.
Register and download the manual for free at retrevo.com http://www.retrevo.com/support/Velodyne-CHT-12-Subwoofers-manual/id/866dj583/t/2/
3/24/2011 5:19:49 PM • Velodyne CHT-12... • Answered on Mar 24, 2011
Pioneer vsx-d814 will not power up
Not a Velodyne product Bad post
12/20/2009 5:09:58 AM • Velodyne CHT-12... • Answered on Dec 20, 2009
CHT12 speaker cuts out randomly have to turn off
Here is something you can try.
On your source check the output level for your sub.
Try setting up at a higher level, if at 1 set it for 2 or 3
Then adjust the volume control on the sub down to mach the speaker volume level.
11/29/2009 11:31:17 PM • Velodyne CHT-12... • Answered on Nov 29, 2009
My velodyne CHT-12 subwoofer does not turn on
Check for blown fuse?
11/16/2009 12:54:34 AM • Velodyne CHT-12... • Answered on Nov 16, 2009
I hear some noise coming out from the woofer of CHT-12R
It very well could be the spaker leads hitting the speaker cone.
You could check this by removing the amp section from the back.
Remove the screws at the very edge of the amp panel.
9/2/2009 10:50:57 AM • Velodyne CHT-12... • Answered on Sep 02, 2009
Sub seems to not get louder with volume increase.
Try adjusting the frequency cut off of the sub and also play with the gain control on the sub. Turn your system up to where your front speakers are sounding as you like. Then try adjusting the sub to match the fronts so you have a good balance and blend.
8/5/2009 12:35:49 AM • Velodyne CHT-12... • Answered on Aug 05, 2009
Recone M & K Subwoofer
im not sure about reconing,most expiriences ive had turned out not to good however partsexpressusa has replacement speakers and i think they also have recone kits as well. if i may make a suggestion dayton audio makes a really good sub if your in the market for a replacement.-z
2/21/2009 1:25:57 AM • Velodyne CHT-12... • Answered on Feb 21, 2009
Velodyne Hgs- 15x
The driver has a soft foam rubber gasket behind it. It can act like glue on the driver.
Taking the driver out will tear up this gasket, always does, so don't worry about that.
You can try to lever the driver out. Use care not to scratch the baffle.
1/4/2009 8:46:00 AM • Velodyne CHT-12... • Answered on Jan 04, 2009
2answers
Sub-woofer does not turn itself on in 'Auto' mode (signal driven)
For the "auto on" problem.
These will sound very basic, please go with it.
On your signal source, make sure you have the sub set to on.
If you can adjust the output setting on your source, turn this up.
Adjust the volume setting on the sub lower to mach the volume of the main speakers.
You may need to make these adjustments a few times to get them working.
On the hum and noise problem
Check your power outlet for the sub, make sure the polarity is correct. I have found this to not always be right. Also what is on that same circuit. Things like the fridge can cause a lot of noise on the power line. Next check your connecting cables, are they of good quality? Are they running next to anything that may cause interference? Also check you connections to the signal source. Cable and dishes are known for ground problems.
1/4/2009 8:33:23 AM • Velodyne CHT-12... • Answered on Jan 04, 2009
Need the Velodyne VX-11 fuse location & type ¿?
Already answered for DPS-12 in 2011 which suggests a fuse where the power enters, However, your manual mentions no fuse, but 'protection circuitry'. If there is a fuse, it will be inside and on a circuit board. All fuses have the rating on the end cap of glass fuses and on the side of ceramic fuses, which as also colour coded. https://velodyneacoustics.com/pdf/vx-11/VX-11Manual.pdf
Where to find fuse on velodyne vx-10b - Fixya
www.fixya.com > ... > Velodyne > VX-10 Subwoofer
Sep. 11, 2011 - where to find fuse on velodyne vx-10b - Velodyne VX-10 Subwoofer. ... in the manual shows a fuse rating of 2 amps where the power cord enters the box. ... here's a link to the owner's manual: http://velodyne.com/vx-11.html.
3/20/2021 5:10:02 PM • Velodyne Audio... • Answered on Mar 20, 2021
We have a 2.5 year old Velodyne EQ-Max8 Subwoofer. It has suddenly started making loud pulsing sounds. Are you able to give us any advice as to what may be wrong with it? Thanks
It sounds like you may have ripped the passive (the rubber material around the speaker that stretches when the speaker hits. If the passive is not ripped then it may be picking up static, or it could be blown. You can purchase a noise filter fairly cheap and try that.
9/30/2019 10:33:15 AM • Velodyne Audio... • Answered on Sep 30, 2019
0answers
Velodyne CHT-12 Subwoofer Logo
15 questions posted
Top Velodyne Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Velodyne Audio Players & Recorders
Most Popular Question
cht12 speaker cuts out randomly turn off
  • Audio Players & Recorders
