20 Most Recent DB BASS INFERNO BassInferno BI4200 Car Amplifier Questions & Answers
tip
My amp is not working
my Bass Inferno BI4200 with 2000 watts power...is not working in my car ...but it is working fine in my friend's car...can i get th right way to install it ????what is the compatible cable for it? cause i had sony amplifier and it was working very good in the same car !!!
Wiring diagram for a Liebmaya remote to solenoid with top with four wires and a black green on the side.
Question edited to tidy up the written English. This looks link it might be a winch, but you posted to Car Audio! https://www.google.com/search?q=liebmaya+wireless+winch+remote+wiring+diagram ..
3/24/2023 1:29:46 AM • Car Audio &... • Answered 2 days ago
Hello! I need the code for the radio Grundig SC303 , sn: GM0303R1823989
dealer with vin and proof of ownership
3/23/2023 3:44:13 PM • Car Audio &... • Answered 3 days ago
2answers
2002 Citroen Saxo VTR with a locked radio - serial number is: CL040230893721D can anyone help me please with the unlock code? Many thanks
For Clarion radio codes contact this link with all the serial numbers from the radio and they will generate the code for you quickly and cheaply: https://www.vivastreet.co.uk/car-parts/hayes-ub4/car-audio-security-code/311088168
3/22/2023 1:48:09 PM • Car Audio &... • Answered on Mar 22, 2023
2answers
We have car audio that requires code, do you know the options how to unlock it?
If your car audio system requires a code to unlock it, there are a few options you can try: Check the user manual: The user manual for your car audio system may contain information on how to unlock it if a code is required. Look for a section on "security" or "anti-theft" features. Contact the manufacturer: If you don't have the user manual or can't find the information you need, you can try contacting the manufacturer of the car audio system. They may be able to provide you with the code or instructions on how to unlock it. Try common codes: Some car audio systems use a default code, such as 0000 or 1234. Try entering these codes to see if they work. Reset the system: If none of the above options work, you may need to reset the car audio system. This will erase any saved settings and data, including the code. The process for resetting the system will vary depending on the make and model of your car and audio system. Check the user manual or contact the manufacturer for instructions.
3/17/2023 10:03:22 AM • Car Audio &... • Answered on Mar 17, 2023
Working on a Rock-Ola 488 Jukebox. Looking for a block diagram of power distribution
Unfortunately, I do not have access to specific diagrams for the Rock-Ola 488 Jukebox. However, a typical power distribution block diagram would show the power source, such as the power supply, and the different branches of distribution to various components. These could include the amplifier, control circuits, motors, and lighting.
In your case, since you only have the power supply and power amp, you could start by tracing the power wires from the power supply and identifying which wires connect to the power amp. Then, you can look for any other components in the jukebox that require power and trace their wiring to the power distribution network. This should give you a general idea of how power is distributed throughout the jukebox.
3/17/2023 12:41:30 AM • Car Audio &... • Answered on Mar 17, 2023
Proton D940 stereo receiver. What kind of CD player and cables do I need to hook it up to the car?
The Proton D940 stereo receiver features both analog and digital inputs, so you have a few options when it comes to connecting a CD player to the receiver. For a digital connection, you will need a CD player with a digital output, such as a coaxial or optical output, and a digital cable to connect the two. Look for a CD player with a digital output labeled "coaxial" or "optical" and purchase a cable that matches the output on the CD player and the input on the receiver. For an analog connection, you will need a CD player with analog outputs, such as RCA outputs, and an RCA cable to connect the two. Look for a CD player with an analog output labeled "RCA" and purchase an RCA cable with the appropriate connectors to match the CD player and the receiver. Once you have the CD player and cables, connect the CD player to the Proton D940 stereo receiver using the appropriate input on the back of the receiver. If you are using a digital connection, select the appropriate digital input on the receiver using the input selector button on the front of the receiver. If you are using an analog connection, select the appropriate analog input using the same input selector button.
3/15/2023 4:29:43 AM • Car Audio &... • Answered on Mar 15, 2023
TOYOTA NHDN-W56 0845-00P51 | HDD Navigation. How to connect NHDN-W56 to battery please?
Question edited for clarity. Normally you need a harness if it is going in a different vehicle. Crutchfields sell them https://www.google.com/search?q=Toyota+nhdn-w56+wiring+diagram ..
3/14/2023 2:31:01 AM • Car Audio &... • Answered on Mar 14, 2023
What is the HLI port
What is the HLI port on the MTX tna251 amplifier?
3/12/2023 11:28:13 PM • Car Audio &... • Answered on Mar 12, 2023
2answers
Cq-vd6505u Car DVD
You can try to hold the right round selector knob to the right for 10 seconds while unit is on asking for code input. That will work to unlock if the previous owner did not set the 4 digit code. Good Luck
3/11/2023 10:56:58 PM • Car Audio &... • Answered on Mar 11, 2023
How do I reset a TRP am/fm cd player. When i turn it on it says P55 2001
This is an old question but I recently had the same problem. The owners manual says to press and hold the band and preset 1 buttons simultaneously. This did not work for me. I removed the radio from the dash and pulled the fuse on the back of the radio. Replacing it after a few seconds reset the radio.
3/6/2023 2:41:06 PM • Car Audio &... • Answered on Mar 06, 2023
2answers
Need radio code for Peugeot 206 please?
This is the 3 ways to get a radio code Jane. We get asked it so often, I wrote a FixYa Tip on it. https://www.fixya.com/support/r29874205-need_vehicle_radio_code ..
2/28/2023 5:57:07 PM • Car Audio &... • Answered on Feb 28, 2023
My pure cd player keeps changing source to AUX. How do I stop this from happening.
If your Pure CD player keeps changing source to AUX, it may be due to a few different reasons. Here are some troubleshooting steps you can try:
  1. Check the connections: Make sure that the cables connecting your CD player to your speakers or amplifier are securely plugged in. Loose or faulty connections can cause interruptions in the signal and trigger the player to switch to AUX mode.
  2. Clean the input selector switch: If your CD player has an input selector switch, dust and debris may accumulate over time and cause the switch to malfunction. Clean the switch using a can of compressed air or a soft-bristled brush.
  3. Check the settings: Some CD players may have settings that automatically switch to AUX mode when no signal is detected from the CD player. Check your user manual to see if your CD player has this feature and how to turn it off.
  4. Reset the CD player: Turn off your CD player and unplug it from the power source for a few minutes. Then, plug it back in and turn it on to see if the issue is resolved.
  5. Contact the manufacturer: If none of the above solutions work, it may be necessary to contact the manufacturer's customer support for further assistance. They may be able to provide additional troubleshooting steps or arrange for a repair or replacement of your CD player if necessary.
Note: Before attempting any maintenance or repair work on your CD player, be sure to read the user manual thoroughly and follow any safety precautions.
2/28/2023 5:09:10 AM • Car Audio &... • Answered on Feb 28, 2023
It i stuck on the cd button and I can not get it to change
If your device is stuck on the CD button and you're unable to change it, try the following steps:
  1. Check the device's manual: First, consult the manual for your device to see if there are any specific instructions for changing the input source. Some devices may require a particular button sequence or menu selection to switch inputs.
  2. Power cycle the device: Turn off the device and unplug it from the power source for a few minutes. Then, plug it back in and turn it on again. This may help to reset the device and allow you to change the input source.
  3. Check the remote control: Ensure that the batteries in the remote control are working properly and that you are using the correct remote control for the device. Some devices may require a specific remote control to change inputs.
  4. Try a different input: If you're unable to change the input from the CD button, try selecting a different input button such as the radio or auxiliary input. This may help to reset the device and allow you to change the input source.
  5. Contact the manufacturer: If none of the above steps work, contact the manufacturer for assistance. They may be able to provide additional troubleshooting steps or suggest repairs or replacement options.
Hopefully, one of these steps will help you resolve the issue and allow you to change the input source on your device.
2/27/2023 10:52:22 PM • Car Audio &... • Answered on Feb 27, 2023
Does anyone have schematic for audiotrak 500 amplifier?
I don't have access to specific schematics for the Audiotrak 500 amplifier. However, there are a few options you can try to obtain the schematic:
  1. Check the manufacturer's website: The first place to look for a schematic is the manufacturer's website. Most manufacturers provide support documentation, including schematics, for their products on their website.
  2. Contact the manufacturer: You can also try contacting the manufacturer directly and asking if they can provide you with a schematic for the Audiotrak 500 amplifier. They may be able to provide you with the schematic or direct you to a source where you can obtain it.
  3. Search online: You can also try searching for the schematic online using search engines like Google or Bing. Enter the model number of the Audiotrak 500 amplifier along with the term "schematic," and you may find a PDF version of the schematic available for download.
  4. Consult with a professional: If you're not able to obtain the schematic through these methods, you can consult with a professional, such as an electronics repair technician. They may have access to the schematic or be able to assist you in troubleshooting the amplifier without the schematic.
I hope these options are helpful in your search for the schematic for the Audiotrak 500 amplifier. Does anyone have schematic for audiotrak 500 amplifier? I'm sorry, but as an AI language model, I don't have access to specific schematics for the Audiotrak 500 amplifier. However, there are a few options you can try to obtain the schematic:
2/27/2023 2:39:22 PM • Car Audio &... • Answered on Feb 27, 2023
DB BASS INFERNO BassInferno BI4200 Car Amplifier Logo
4 questions posted
Top DB BASS INFERNO Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a DB BASS INFERNO Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • DB BASS INFERNO Car Audio & Video
Most Popular Question
recently rebuilt transmission 4r70w 01
  • Car Audio & Video
