20 Most Recent Kenmore 73089 Air Conditioner Questions & Answers
Sounds like a short in the wire. Not sure if that board powers off high or low voltage but I would say you definitely have a short. You need to replace the supply voltage wire.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Kenmore 73089... | Answered on May 14, 2017
Check the cord. Reset it. Check the circuit breaker. Is the filter clean?
If all of that is good you could have a bad capacitor. If it looks swollen or leaky that is the problem. A bad capacitor could cause the fan and compressor not to run IF the power is there. More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore 73089... | Answered on Jul 06, 2010
DO you have a way to make sure the power is on at the plug?
Kenmore 73089... | Answered on Mar 26, 2009
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Kenmore 73089... | Answered on May 27, 2008
Put something underneath the front of the unit (like a magazine) so it tilts slightly this should allow the water to get to the condenser area and be evaporated out the vent.
Kenmore Heating... | Answered on Jun 27, 2019
are you making sure to push both breakers completely off before pushing them back on
Kenmore Heating... | Answered on May 06, 2019
Without a serial number you cannot look up on line what the unit age is. Have you cleaned the condenser coils on the bottom and back of unit?
Kenmore Heating... | Answered on Aug 27, 2018
Here is the link to the manual
Kenmore Heating... | Answered on Aug 23, 2018
First, I'm not a Kenmore representative.
* Check your warranty. Call for support
* Contact; https://www.sears.com/en_us/botmanagement.html
* Note; Sears support section might not be working.
* Kenmore support; https://www.kenmore.com/customer-care/
*** The following is for information only.***
* 42-79081 8K BTU; https://c.shld.net/assets/docs/spin_prod_786787012.pdf
* Install 5K-8K BTU air conditioners; http://www.specsserver.com/CACHE/FRTHXFYQBVDB.PDF
* Common problems; https://www.youtube.com/watch?v=Fc37Nghr9qY
* Trouble shooting; https://www.youtube.com/watch?v=sqocUT0PR6o
* Call your local refrigeration service or local Kenmore dealer for additional advice.
Aloha, ukeboy57
Additional info;
* customer's review; https://www.youtube.com/watch?v=0JX7J62mWIM
* Cleaning; https://www.youtube.com/watch?v=mUlOUhPBQmM
* Elite (smart model); https://www.youtube.com/watch?v=6FAgzqQ_pKA
* DIY Fix (May Void warranty); https://www.youtube.com/watch?v=6QLywLib_v8
* Installing (larger) units; https://www.youtube.com/watch?v=oEXduKMpTlE
* Customer cleaning (without removal); https://www.youtube.com/watch?v=_6bo87N-Xp8
Kenmore Heating... | Answered on Aug 07, 2018
possibly refrigerant related, likely a call for service in your future. Clean coils and filter first!!
Kenmore Heating... | Answered on Jun 15, 2018
is the relay side sensitive? installed upright? what's starting amps on compressor? verify all connections tight, obviously replace start kit first but possibly compressor going bad.
Kenmore 73089 Air Conditioner Logo
5 questions posted
Top Kenmore Heating & Cooling Experts
jdthefixer
Sheldon Dedek
Mike
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Heating & Cooling
Most Popular Question
kenmore 73089 ac keeps blowing control
  • Heating & Cooling
