20 Most Recent
Rossignol Used Freeride X 05 Skis with Ski Bindings Questions & Answers
Vertical adjustment on front binding. Salomon S810 Ti
If you can adjust vertical pressure then you should adjust it as follows.
Put a piece of normal paper (like A4 printer paper) on the toe bit (and heel for that matter) and clip in the boot so that the paper sits between the boot sole and the binding base surface. You should be able to pull the paper out from between the boot and binding without ripping the paper, but obviously without there being a noticeable gap.
If in doubt take it to a ski tech, a bit of cash might save you a broken leg! They might even be able to help you or advise free of charge.
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like
How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
How to change ignition on a 2014 tundra lt 550 f ski-doo
It's pretty basic and old school on all 550's and 380's unplug the back of the ignition ( it will now start without the key using the pull cord) remove the rubber boot from the ignition and unscrew the nut holding the ignition. Don't know why it needs replacement they pretty much never fail my 09 gtx 550 has over 12k and no problem except freezing occasionally.
