20 Most Recent
Velodyne VRP-1200 Subwoofer Questions & Answers
Right side audio valume not working
Do you mean that the right speaker which is routed through the subwoofer's Speaker Level In and Out is not working? Did it all start when you added the subwoofer?
Perform some isolation and connect that speaker directly to your receiver to see if it works.
YES? Recheck the speaker connections. After all, the sub is only connecting your receiver to the speakers after borrowing LFE information. Observe matching + and - polarity throughout.
NO? Either the speaker or the Receiver channel have a problem, but that isn't likely if the problem appeared just from putting the subwoofer into the mix. You can swap speakers to eliminate them and swap source amplifier channels to isolate them.
5/16/2009 12:46:25 PM •
Velodyne...
Answered
on May 16, 2009
Woofer,s outer ring is ripped.
To fix this problem, you will need to contact Velodyne.
They may be able to replace the surround or recone this driver.
Because this system has the "servo" control, you need to have the accelerometer conected to the amplifier. With out it, the amplifier will not operate.
1/4/2009 7:59:01 AM •
Velodyne...
Answered
on Jan 04, 2009
