20 Most Recent Kenmore 24.9 cu. ft. / 705 liter Chest Freezer 13551 Questions & Answers
Search online to find the manufacturer's website. Call or email them. Be sure to have the model number and serial number. They should be able to help you.
Kenmore 24.9 cu.... | Answered on Jan 07, 2015
You can get the key on the link below.
http://www.repairclinic.com/SSPartDetail.aspx?s=b6a3i12849&PartID=12849
Good Luck and please rate 4 thumbs up for the free answer.
Kenmore 24.9 cu.... | Answered on May 07, 2010
Call back the technician who installed the compressor.
Normal operation is mid position, not all the way up.
Do you Hear anything when you ON the Freezer like Clicking Noise or Humming Noise. If NO, follow the Below steps :-
Check to see if the thermostat has continuity when turned to the coldest setting, if that is okay then you will want to disconnect the wires going to the compressor and see if you get 120 volts there after is plugged in, if you get that I would replace the overload / relay on the compressor and see if that gets it to work, if that does not work your compressor is shot and not worth fixing.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Kenmore 24.9 cu.... | Answered on Dec 12, 2009
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
Kenmore 24.9 cu.... | Answered on May 29, 2009
Tip
Freezer icemakers troubleshooting tips
Some Electrolux (parent company) freeezers like whirlpool and Kenmore use an optics emitter and receiver to detect when the ice bucket is full. if either device fails the icemaker quits functioning. review attached troubleshooting chart:
on Jun 10, 2020 | Freezers
I just bought a Kenmore Heavy Duty Chest Freezer with quick freeze that has been unplugged. The alarm is on and it is flashing FF
Kenmore Freezers | Answered on May 15, 2020
I would check the actual light fixture; They are not cheap to replace at about 75 dollars for the part, They can have bad connections at the board level or it could be the door switch.
Kenmore Freezers | Answered on Apr 13, 2020
GIVE IT TIME SO THE THE SYSTEM COULD STABILIZE IT SYSTEM FOR A FRESH STARTUP. OR HAVE CHECK TO ITS OVERLOAD UNIT THE COMPRESSOR MOTOR.
Kenmore Freezers | Answered on Jan 02, 2020
yes
Upright Freezers ' Kenmore
https://www.kenmore.com/products/refrigeration/freezers-and-ice.../upright-freezers/
Kenmore upright freezers are great for the garage, basement, or pantry. ... These freezers come with a manual or frost-free defrost system, to keep rarely used foods from expiring early. ...
Kenmore Freezers | Answered on Jul 24, 2019
It may be a sensor. Don't replace a control center unless you have determined it's bad. The sensor has to be wired to the board controller. Usually smaller cable with 2 conductors. If it has an alarm then there may g e as many as 6 or 8 or more wires going to the board. Using your wire diagram Find the sensor for temp. Sometimes the ohm value is given on the wire diagrams. You will also need the temperature at the point the sensor is connected inside. Your ohm reading should be close to the temp given in a table or from the manufacturer. If it's close sensor ok. Take next step.
Kenmore Freezers | Answered on Jan 18, 2019
Does it have a high temperature alarm? I have an older Kenmore with this that requires a 9 volt backup battery to activate the alarm if the power goes off. If the battery goes dead over time, the alarm won't shut off even with the power on. My battery is behind a small door on the left side end of the plastic floor dress plate on the bottom front of the freezer. I use a 9 volt lithium battery myself. I have a backup generator so it doesn't have a lot of time to run on the battery. Where an alkaline battery lasts me about 18 months, This lithium battery has been in for 3 years and shows no sign of failing yet. They have a shelf life of 15 years or more all though they won't last that long in this application. It's worth not coming home and not finding the dogs going wild due to the high pitched beep. Good luck.
Kenmore Freezers | Answered on Dec 31, 2018
Never heard of an electric freezer with a 9v battery. What is freezer model #?
Kenmore Freezers | Answered on Nov 20, 2018
Kenmore 24.9 cu. ft. / 705 liter Chest Freezer 13551 Logo
6 questions posted
Top Kenmore Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Freezers
  • Kenmore Freezers
Most Popular Question
need part number replacement key
  • Freezers
