20 Most Recent Kenmore Freezer 14.1 cu. ft. Upright Freezer with Hose Adapter Questions & Answers
You have to fix crack , as it will keep your compressor running the kill your compressor. You fix the leak at local repair shop
Kenmore Freezer... | Answered on Jan 04, 2011
dear sir /madam
please turn to your thermostat nobe clock vise till the end you will got the highest cooling point for lowest turn this nobe anti clock vise position till end it,s lowest point of cooling.
hope answer the question.
please vote!
thank you
Kenmore Freezer... | Answered on Sep 05, 2010
You'll need to get a blow dryer and then thaw it out so it can flow again. Move your frozen foods into the fridge while you do this. Let me know what happens. I might have another few ideas. Raz
Kenmore Freezer... | Answered on Apr 21, 2010
These are the parts that would make a clicking noise. it is up to you to pin point where it is coming from:
compressor
timer
icemaker
fan
ok try to pin point if the clicking is coming from the inside or the outside
you can go to sears.com hit the parts link then enter the model number. you can view a diagram and it will show you where the parts are at
hope this helps
Kenmore Freezer... | Answered on Apr 04, 2010
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Kenmore Freezer... | Answered on Feb 25, 2010
Control is bad and needs to be replaced. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Kenmore Freezer... | Answered on Nov 28, 2008
Tip
Freezer icemakers troubleshooting tips
Some Electrolux (parent company) freeezers like whirlpool and Kenmore use an optics emitter and receiver to detect when the ice bucket is full. if either device fails the icemaker quits functioning. review attached troubleshooting chart:
on Jun 10, 2020 | Freezers
I just bought a Kenmore Heavy Duty Chest Freezer with quick freeze that has been unplugged. The alarm is on and it is flashing FF
Kenmore Freezers | Answered on May 15, 2020
I would check the actual light fixture; They are not cheap to replace at about 75 dollars for the part, They can have bad connections at the board level or it could be the door switch.
Kenmore Freezers | Answered on Apr 13, 2020
GIVE IT TIME SO THE THE SYSTEM COULD STABILIZE IT SYSTEM FOR A FRESH STARTUP. OR HAVE CHECK TO ITS OVERLOAD UNIT THE COMPRESSOR MOTOR.
Kenmore Freezers | Answered on Jan 02, 2020
yes
Upright Freezers ' Kenmore
https://www.kenmore.com/products/refrigeration/freezers-and-ice.../upright-freezers/
Kenmore upright freezers are great for the garage, basement, or pantry. ... These freezers come with a manual or frost-free defrost system, to keep rarely used foods from expiring early. ...
Kenmore Freezers | Answered on Jul 24, 2019
It may be a sensor. Don't replace a control center unless you have determined it's bad. The sensor has to be wired to the board controller. Usually smaller cable with 2 conductors. If it has an alarm then there may g e as many as 6 or 8 or more wires going to the board. Using your wire diagram Find the sensor for temp. Sometimes the ohm value is given on the wire diagrams. You will also need the temperature at the point the sensor is connected inside. Your ohm reading should be close to the temp given in a table or from the manufacturer. If it's close sensor ok. Take next step.
Kenmore Freezers | Answered on Jan 18, 2019
Freezers Logo
13 questions posted
Top Kenmore Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Freezers
  • Kenmore Freezers
Most Popular Question
coldest dial 1 or 8
  • Freezers
