20 Most Recent Life Fitness Stamina 1205 Precision Rower Questions & Answers
Where can I get the following part: Stamina 1205
CALL US:
Call a Stamina Customer Service Representative
at 1-800-375-7520 during office hours:
Monday - Thursday
8 a.m. until 5 p.m.
Friday
8 a.m. until 3 p.m.
E-MAIL:
Send your e-mail questions and comments to:
[email protected]
4/24/2017 6:31:15 PM • Life Fitness... • Answered on Apr 24, 2017
Looking for manual for body sculpture br-3200
Looking fo manaul
2/13/2016 7:12:06 PM • Life Fitness... • Answered on Feb 13, 2016
Stamina 1205 Rowing Machine
mine did this as well--turn the shock 180 degrees so the sticker is down and the caution sticker--this fixed mine. The shock is probably slightly off from the factory and is in a bind the other way. Hope this fixes the problem for others.
12/15/2012 9:22:41 PM • Life Fitness... • Answered on Dec 15, 2012
0answers
Need user manual for Stamina 1205 rowing machine
the owner manual pdf file is here:
http://www.efitnessdirect.com/product.php3?id=492
12/18/2009 12:55:19 AM • Life Fitness... • Answered on Dec 18, 2009
My treadmill LIFE FITNESS T3 blocked and the console display the following message : ERR 6 / ERR KEY BLOCKED. Turn ON /OFF. Does not fix the problem. What does it mean and how to proceed? Thank you.
How do I fix error 6 on my treadmill? E6 Error: Controller malfunction. Resolution: Ensure that the cables connecting the console and the controller are secure. If any of the cables/connectors appear loose, completely power off and unplug the treadmill before unplugging and reattaching the cables.Sep 23, 2021
E6 Error Code: Control Board Malfunction - Spirit Fitness Support
https://www.google.com/search?q=LIFE+FITNESS+T3+ERROR ..
1/28/2024 11:47:14 PM • Life Fitness... • Answered on Jan 28, 2024
Incline Error Life Fitness TR9100HR
1/4/2024 2:03:40 PM • Life Fitness... • Answered on Jan 04, 2024
Life fitness t7-o shows "communication timeout" error when adding resistance to the belt.
Try to lubricate the belt and then use it. It seems the control temperature is getting above normal due to load
10/13/2023 5:26:13 PM • Life Fitness... • Answered on Oct 13, 2023
2answers
Motor disabled error on life fitness treadmill after 1min On 95ti model
check wiring and sensor
7/28/2023 8:56:41 AM • Life Fitness... • Answered on Jul 28, 2023
Life Fitness Club Series+ treadmill, miles to kilometers?
Hi Yuri, Hope so you're doing well, the distance unit from miles to kilometers on the Life Fitness Club Series+ treadmill, there are a few steps you can try before contacting Life Fitness support:
  1. Warm reset: Press the CLEAR key twice, and then hold down the ENTER key. The treadmill should perform a "warm" reset and beep three times, indicating that the USER MENU has been activated. After the reset, check if you can access the distance unit setting.
  2. Manual access: Alternatively, you can try holding down the ENTER key while turning on the treadmill. The message "USER MENU" should appear, and after a second, the MESSAGE CENTER will display the first menu item. Navigate through the menu options using the appropriate keys until you find the distance unit setting.
Hope so this will work for you! Regards, Bryce June
6/3/2023 7:54:26 PM • Life Fitness... • Answered on Jun 03, 2023
Lifefitness se3 hang up how can i fix it ?
Sure, here are some steps you can try to fix the issue with your Lifefitness SE3 console:
  1. Perform a system diagnosis: The Lifefitness SE3 console has a built-in diagnostic tool that can help you identify any hardware or software issues. To access this tool, press and hold the 'Home' and 'Volume Up' buttons for 5 seconds. Then select 'System Diagnostics' from the menu and follow the prompts to perform the diagnosis.
  2. Check the system logs: The Lifefitness SE3 console logs all system events, which can help you identify the cause of the hang-up. To access the logs, go to the settings menu and select 'System Logs'. Look for any errors or warnings that may indicate a problem.
  3. Update the BIOS: The Lifefitness SE3 console has a BIOS (basic input/output system) that controls the hardware and software interactions. Updating the BIOS can sometimes fix issues with the console. To update the BIOS, download the latest BIOS firmware from the Lifefitness website and follow the instructions provided.
  4. Check the storage device: The Lifefitness SE3 console uses an embedded storage device to store data and software. If this storage device is faulty, it can cause the console to hang-up. To check the storage device, go to the settings menu and select 'Storage'. Look for any errors or warnings that may indicate a problem.
  5. Reinstall the operating system: If none of the above steps work, you may need to reinstall the operating system on the console. To do this, download the latest operating system firmware from the Lifefitness website and follow the instructions provided.
3/22/2023 8:57:51 PM • Life Fitness... • Answered on Mar 22, 2023
How can I turn down beeping on Life Fitness 95xi elliptical? My wife pedals slowly on it and it's constantly restarting and beeping and beeping and beeping.
To turn down or turn off the beeping on your Life Fitness 95xi elliptical, follow these steps:
  1. Locate the control panel: The control panel is usually located near the handlebars or on the console of the elliptical.
  2. Find the sound or beep settings: Look for a sound or beep option in the settings menu.
  3. Adjust the volume or turn off the beeping: Use the up and down buttons to adjust the volume of the beep, or turn off the beep completely.
  4. Save the changes: Once you have made the necessary adjustments, be sure to save the changes by pressing the "Save" or "Enter" button.
If you are unable to find the sound or beep settings, consult the owner's manual or contact the manufacturer for assistance. Keep in mind that some beeps are important safety warnings, and disabling them could be dangerous.
2/6/2023 12:48:56 AM • Life Fitness... • Answered on Feb 06, 2023
Life FItness elliptical model X7 has too much resistance on startup. Prevents use for warming up.
It sounds like the resistance on your Life Fitness X7 elliptical is set too high for the machine to be used effectively as a warm-up tool. There are a few things you can try to adjust the resistance on the machine.
  • Check the user manual that came with the elliptical to see if there are any specific instructions for adjusting the resistance.
  • Check the resistance settings on the dashboard to ensure that they are set to the correct level.
  • Check the resistance adjustment knob or lever to ensure that it is not stuck or jammed in place.
  • Check the belt tension on the elliptical to ensure that it is not too tight.
  • Check to ensure that there is no debris or dust in the resistance mechanism.
  • If the issue still persists after trying the above steps, it may be best to contact Life Fitness technical support or consult a technician for further assistance.
It is also a good idea to inspect the machine overall for any damage or wear. If all else fails, the used elliptical may have a defect or may not be compatible with your needs. You may need to consider purchasing a new one or a different model for your clients warm-up needs.
1/14/2023 10:34:22 PM • Life Fitness... • Answered on Jan 14, 2023
I have a Life Fitness 95x elliptical and at low speed the resistance gets very hard briefly and then frees up
Hi, The resistance might be caused by internal gears are probably switching when you initially slow down. It's the same as when you're decelerating in a car prior to accelerating and the car has resistance when you're going at a speed just before the car gears shift. Thank you.
12/29/2022 12:43:29 AM • Life Fitness... • Answered on Dec 29, 2022
Life Fitness Stamina 1205 Precision Rower Logo
Popular Tags
11 questions posted
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Life Fitness Exercise & Fitness
Most Popular Question
looking manual body sculpture br 3200
  • Exercise & Fitness
