20 Most Recent Endurance TF3i Folding Treadmill Questions & Answers
bodysolid.com
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Endurance TF3i... | Answered on Oct 15, 2017
Here's what the Sole exercise equipment makers say about calorie counters on exercise equipment. it's from their E-95 users manual: "Calorie readings on every piece of exercise equipment, whether it is in a gym or at home, are not accurate and tend to vary widely. They are meant only as a guide to monitor your progress from workout to workout. The only way to measure your calorie burn accurately is in a clinical setting connected to a host of machines. This is because every person is different and burns calories at a different rate. Some good news is that you will continue to burn calories at an accelerated rate for at least an hour after you have finished exercising!"
Endurance TF3i... | Answered on Nov 24, 2016
Those ripples sound like the product of an old belt from it stretching over time, you may just need to replace the belt.
If you have a two sided deck, it is best for the machine when putting in a new belt to flip that deck or if you don't have a flippable deck to get a new deck along with that new belt.
When you replace these items it is a good idea to go ahead and perform maintenance on a few other items, including but not limiting it to your Motor Control Board, Front and Rear rollers, and by maintenance we just mean clean and remove debris or dust bunnies from the treadmill.
It will help the life of those other components along with being a must, especially on those front and rear rollers when replacing the deck and belt.
Do not forget to lubricate your belt and deck after proper installation.
If you find yourself needing any further assistance please do not hesitate contacting our Technical Support Team by chat at www.sportsmith.net or by phone at 888-713-2880 we would be happy to help :)
Endurance TF3i... | Answered on Aug 13, 2015
for the most part treadmills are self sustainable and do not need oiling or maintenance but you can check the owners manual for your model to see if you should or can do so. (Google is your friend).
Endurance TF3i... | Answered on Sep 27, 2012
2 options:
1) Elevation motor can be faulty a) lube the gear and shaft b) adjust the potentiometer. However is better RUN the software calibration for diagnose, and troubleshooting.
2) Display board, adjust the reed switch, see the diagram attached, clean, and tight the wire connector very well.
sincerely. God bless you
Endurance TF3i... | Answered on May 06, 2012
there are 2 options with this error:
1) The elevation motor: Run the software calibration for diagnose, troubleshooting, and fix it. a) lube the gear and shaft very well b) adjust the potentiometer c) test the motor if o.k or faulty d) see if relais for up and down is clean the contacts.
2) Display board: adjust the reed switch see the diagram attached.clean, tigh the wires connector.
Dear Sir:
You can be fix it.
1) See the diagram attached, and adjust it, clean, and tigh the wire connector very well.
2) Test the input voltage for motor, if there are voltage, the motor need repair.
3) Test the output voltage board, for the input voltage motor, if there are NOT, the board is faulyt.
4) However RUN the software calibration for diagnose, troubleshooting, and fix it.
Dear Sir:
This error has 2 options:
1) Elevation motor a) motor need maintenance b) gear and shaft lube c( adjust the potentiomenter d) motor faulty.
2) Display board a) need adjust the reed switch see the diagram attached.
5_4_2012_1_14_17_am.gifsincerely. God bless you
Endurance TF3i... | Answered on May 04, 2012
Dear Sir:
1) Alternative is the elevation motor: a) motor need maintenance b) lube the gear and shaft c) adjust the potentiometer. d) motor faulty.
2) Display board need adjustment Reed switch, see the diagram attached, clean, and tight the connector very well.
error 1 simply means no belt movement generally. If belt moves a little it could be the speed sensor but generally it's the motor controller.
Endurance TF3i... | Answered on May 05, 2011
Actually it means you have been a avid user of your unit.
Unplug the unit remove the motor shroud, then go to the end of your unit I believe it uses an allen wrench loosen the belt. Now while at this portion count how many times you have turn the bols son each side then write it down so when you are ready to apply the same tension you be in the ball park. Now what you need to do is actually see if it is the front unraveling or it is the running belt. then that said done call BH and order the part or parts needed complete the repair or ask them if they have a reliable servicer in the area to complete the repair for you.
Endurance TF3i... | Answered on May 06, 2010
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Endurance TF3i... | Answered on Apr 30, 2010
"The best treadmills are those that provide you easy access to belt tracking. But, even the best treadmills with the most easily accessible belt tracking are also susceptible to stretch slightly under initial use. That is why it is important that you adjust the tread belt every so often to keep it away from stretching. Most manufacturers include the Allen wrench (a tool consisting of a hexagonal head and an L-shaped bar) in the package when you buy a treadmill from them. Use it to tighten both the belt adjustment screws clockwise. If your manufacturer did not supply you with an Allen wrench, use another of the right size. A ¼ turn, clockwise should tighten treadbelt if it has loosened. The screws for belt adjustment are usually located at the rear end of the treadmill. Some belts do require looser running than others so don’t be surprised if your treadbelt is a little loose even when you haven’t actually used it. Check the user’s guide before making adjustments just to make sure that whatever you are doing is correct. Moreover, be sure to keep the belt running at a low speed of around 3 mph when adjusting the belt tracking. This is the ideal speed when making any adjustments with the screws. Maintaining your treadmill is necessary to upkeep it's performance and looks. A little bit of adjustment here and there can make your treadmill a life long companion. "
Endurance TF3i... | Answered on Dec 31, 2008
Endurance TF3i Folding Treadmill Logo
27 questions posted
Top Endurance Exercise & Fitness Experts
vinayghl
Tom Chichester
Info Hub
Info Hub
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Endurance Exercise & Fitness
Most Popular Question
accurate calorie counters treadmills car
  • Exercise & Fitness
