20 Most Recent Dell Latitude D610 Laptop Computer - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G PC Notebook Questions & Answers
You may need to install WinDVD , Interactual Video player, or some similar video player software. The drive will read data CD's and DVD's with Windows , but it needs video codecs (supplied with the video player software) to play DVD movies and media.
Dell Latitude... | Answered on Oct 31, 2019
You can download the DELL D610 driver from the link below. You can also download all other drivers and utilities from this link.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WLH&osl=en&catid=&impid=&SystemID=LAT_PNT_PM_D610
Dell Latitude... | Answered on Jan 31, 2019
No You have to purchase an upgrade Windows 7.
Dell Latitude... | Answered on Dec 01, 2016
From this web site:
http://www.computerhope.com/issues/ch000594.htm
How do I adjust my brightness or contrast on my laptop? Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
Other examples also shown in the above picture include pressing Fn and F1 and F2 or F7 and F8 to increase and decrease the brightness. If none of the above examples resemble your keyboard look for keys on the keyboard that have pictures of a sun or a half moon to identify the correct key to adjust the brightness.
How can I adjust the laptop contrast? Laptops only allow users to adjust the brightness of their screen. Contrast settings are not adjustable on a laptop display.
How do I save the new adjusted settings? After adjusting your laptops brightness it will retain the new settings.
Laptop brightness is still not enough or screen is black If after following the above steps your brightness is still not enough, plug your laptop into the wall to make sure it is not a power setting that is decreasing the brightness. If the laptop is plugged in but still is not bright enough, try the suggestions on the below link.
Dell Latitude... | Answered on Aug 03, 2015
There are 3 moving parts with motors on a laptop.
1. The HDD
2. The CPU fan
3. The CD/DVD/Blue ray drive
Check them
If it's the HDD than you will be having problem with the operating system. Back up your data and change with a new HDD. 50$ to 80$ depending on your choice of HDD.
If it's the CPU fan it might be touching a cable or the casing. For this you need to dismantle the laptop and clear this out or change the fan. 10$.
If it's the CD/DVD/Blue ray drive than the laser eye is starting to loose it's ability. You will need to change the drive. 30$ to 50$.
Good luck mate.
Dell Latitude... | Answered on Dec 07, 2014
connect a desktop monitor to VGA port from your laptop. if there will able to see the displays?.. you can go to control panel to reset the display settings and back that on to the normal screen settings.
Dell Latitude... | Answered on Sep 05, 2014
If you mean from one computer to another, why not just use a usb driveor a cd?
Dell Latitude... | Answered on Jul 22, 2014
The motherboard has been changed. The code is motherboard specific , and , for this laptop, it may mean you need different drivers , since more than 1 chipset was used in production. Go to Dell.com , click on support, and enter the actual service tag number, not the one on the outside to verify drivers.
Dell Latitude... | Answered on Jul 19, 2014
It may sound stupid, but some people do not know that deleted messages are stored in the recycle bin . Click on Start ' Help and support and you should find version specific info for your version of windows ( just enter recycle bin in the search box). If you have already emptied the recycle bin , google active software and try their unerase application.
Dell Latitude... | Answered on Jul 06, 2014
You can click on Start ' Control Panel ' Power Options. The Power Meter tab will give you battery status (charge level) , and the Advanced tab will allow you to select a check box to put a battery status icon in the systray (lower right corner of the screen). Remember to click the Apply button to make changes permanent.
Go to the DELL support page
http://support.euro.dell.com/support
Click drivers & download
enter your system type and model
You will then be presented with all the drivers for your D610.
Download the Sigmatel driver in the Audio section.
Save the file then run to install the driver.
Dell Latitude... | Answered on Jun 30, 2014
please identify operating system (Windows XP, Windows 7, Vista Business,etc.) and tell me if it is locking up before or after it reaches the login screen
Dell Latitude... | Answered on Jun 01, 2014
Please refer to the link provided below. It may answer your questions, at least in part.
http://www.command-tab.com/2005/12/23/hacking-dell/
Dell Latitude... | Answered on May 29, 2014
Using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
Dell Latitude... | Answered on May 02, 2014
password for windows or bios .. if bios send me service tag.. thanks
Dell Latitude... | Answered on Mar 16, 2014
Go to BIOS settings and check what is the order of BOOT devices there. Ensure that you have HDD as the first option if you want to boot from a hard drive. You can accordingly chose the 2nd and 3rd options to fit your requirement
Dell Latitude... | Answered on Jan 01, 2014
  1. Turn on (or restart) your computer.
  2. When the DELL logo appears, press <F2> immediately. If you wait too long and the Windows logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again.
  3. Look for Boot Order or boot sequence. You will see a list of boot devices. Whatever you want as 1st device needs to be selected in 1st or move them to TOP. It depends on your BIOS version. But this is very close to what you are looking for. Good luck, If you still cant find it then Message me. I will guide you through it.
  4. http://www.solano.edu/technology/data/D610/setup.htm
Dell Latitude... | Answered on Dec 30, 2013
Dell Latitude D610 Laptop Computer  - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G  PC Notebook Logo
201 questions posted
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
LATITUDE Dell
  • LATITUDE Dell
Most Popular Question
want safely remove clean replace all
  • Computers & Internet
