20 Most Recent Huffy So Sweet Girls 20-Inch Bike Questions & Answers
Missing front rim where can I order new one?
go to your local bike shop, they can get you a 20" wheel that is much better quality than what was originally spec'd on the bike for about $30. Huffy doesn't sell OEM replacement parts for their bikes.
11/2/2015 6:32:58 PM • Huffy So Sweet... • Answered on Nov 02, 2015
THE WRONG MANUAL CAME WITH THE SO SWEET BIKE. I
go to my tips and tricks page. There is a link to Huffy to get a new manual for the right bike.
12/21/2010 7:49:23 AM • Huffy So Sweet... • Answered on Dec 21, 2010
How to assemble back tire barrens and other parts
I'm guessing this bike has a rear coaster brake. I really don't suggest overhauling a coaster brake hub and it is unlikely a diagram for your huffy exist but here is a link to a general coaster brake hub diagram. It should be very similar to what you are working on.
http://www.wtlw.net/ff/suntour/
Hope this helps!
7/22/2009 1:21:11 PM • Huffy So Sweet... • Answered on Jul 22, 2009
Brake assembly help!!!!!!!!!
1. the other end of the brake cable with the stopper,insert to the handle brakes.there is a guided slot for it.
2.go to the brake assembly.loosen the nut and find the small hole at the shaft of the flat head bolt.insert the cable.
3. adjust the brake.pull the cable until it is in the best tension,slowly rotate the brake nut to keep the cable in place.
4. try to grip the brakes and try pushing the bike while testing the tires if it skid.try to ride it to so that your weight will be calculated with the brakes.
5. adjust the brakes by repeating the above instruction until desired brake adjustment is achieved.
5/31/2009 3:56:53 AM • Huffy So Sweet... • Answered on May 31, 2009
Parts for Huffy Maxx? I need a left side crank and nut.
Question moved from Computers to maker category.
Order Replacement Parts
Huffy Bikes https://www.huffybikes.com > parts We make it easy. Here you can order free warranty parts, or purchase the replacement parts you need. *Note: Battery products including ride-on toys, ... Missing: Maxx ā€Ž' Show results with: Maxx
Order Replacement Parts-Bikes, Scooter, Ride On Toys
Huffy Bikes https://www.huffybikes.com > index > findproduct Order replacement parts for your bikes, scooters, and battery ride on toys. ... and FAQs about warranties, warranty parts, returns and order cancellations. Missing: Maxx ā€Ž' Show results with: Maxx
Huffy Vintage Bike Parts for sale
eBay https://www.ebay.com > ... > Vintage Bicycle Parts Get the best deals on Huffy Vintage Bike Parts when you shop the largest online selection at eBay.com. Free shipping on many items ' Browse your favorite ...
Bike Parts and Accessories
Huffy Bikes https://www.huffybikes.com > parts-accessories Results 1 - 8 of 8 - Bicycle parts, smartphone holders, repair kits, and officially-licensed accessories from Disney and Marvel allow you to get the most out ... Missing: Maxx ā€Ž' Show results with: Maxx ..
8/25/2023 5:24:26 PM • Huffy Cycling • Answered on Aug 25, 2023
2answers
Huffy serial number, 1H037104. I'm in Leavenworth, Ks. Where can I get parts for this & how can I decode this serial number?
Hopefully this site will help you..... https://www.huffybikes.com/contact/ there's a 800# there too. Best to you
2/26/2023 5:51:51 PM • Huffy Cycling • Answered on Feb 26, 2023
What year is my huffy bike serial number htc13b74808 and what's its current value?
Condition and quality determine value. A Huffy, even if older, has very little value.
12/17/2022 4:26:25 AM • Huffy Cycling • Answered on Dec 17, 2022
Model and year of huffy bike serial # 4H114288
Not possible to ID by serial number, and even if it was it's not important. Huffy's are not valuable and parts are not specific to a particular brand, let alone year or model of bike. The model name is printed on the bike's frame. If not there bike has been cheaply repainted, possibly because it's stolen.
12/17/2022 4:20:02 AM • Huffy Cycling • Answered on Dec 17, 2022
2answers
I need a rear axle replacement kit for a huffy nel lusso mens cruiser
I think that you should search on Amazon or Flipcart. Your required things are available on Amazon.
11/25/2022 11:47:54 PM • Huffy Cycling • Answered on Nov 25, 2022
Needto lubricate rear wheel bearings on a huffy single speed bike
as most bikes do not have seals on the wheel axles , it is possible to lay the bike on the side , use machine oil on the hub and axle area and spin the wheel while allowing drops of oil onto the axle bearing hub area or you can take the hub apart and fill with a very light grease
11/11/2022 12:13:34 AM • Huffy Cycling • Answered on Nov 11, 2022
2answers
Where can i buy replacement parts?
10/14/2022 5:17:32 PM • Huffy Cycling • Answered on Oct 14, 2022
2answers
Type of 12v in helix huffy 18887A
Take old battery off first it will tell you on there, as long as it 12volts and the same size then it will do the job.
4/3/2022 12:33:57 PM • Huffy Cycling • Answered on Apr 03, 2022
How to put on a rear axle assemly on a 26 inch perfect frame mens dellusso huffy bicycle
Are you asking about the internal parts like bearings, races, and such, or are you asking how to lace a rim? The first one is fairly straight forward, so I am guessing the second. I have done quite a bit with bikes and never attempted since it is a science and art. There are a few youtube videos but they make it look so easy. One on the issues I hit when thinking about it is having a good tuning stand and dishing guide to get the rim to run in the middle if front wheel of a bit off center on the rear due to the gear cob. I gave up trying to find the tools, right spokes, (before internet) and opted to buy a whole rim. https://m.youtube.com/watch?v=OYl4NO5m16Q
6/11/2021 11:17:26 PM • Huffy Cycling • Answered on Jun 11, 2021
HOW TO DETACH TRAINING WHEEL FROM hUFFY tODDLER BIKE
  1. Begin by removing the outer nut. Using a 15mm spanner (closed end preferred), turn the nut in an anti-clockwise direction when looking at the nut from the same side as the nut is on (Dia.1 below)
  2. Next remove the outer nut, round washer, training wheel and square stabiliser washer. DO NOT loosen or remove inner nut!!
5/30/2021 8:49:00 AM • Huffy Cycling • Answered on May 30, 2021
Do 10 speed huffy mountain bikes have master link on chain for removal?
No, they do not - a chain tool has to be used. Also, a 10 speed (2 gears in front, 5 in the rear) would be quite old, so the rear gear cluster (freewheel) will be worn as well as the chain, and also takes a specialized tool to remove. Replacing both on a Huffy will cost more than the bike is worth.
9/25/2019 12:26:21 PM • Huffy Cycling • Answered on Sep 25, 2019
Is there a way to know the manufacture year of a Huffy motorized bicycle, serial #SNHEJ09C844290?
Google "Huffy motorized bike serial number" and see what you can find. That's all anyone else can do. Iā€™m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
9/10/2019 9:26:22 PM • Huffy Cycling • Answered on Sep 10, 2019
Huffy So Sweet Girls 20-Inch Bike Logo
Popular Tags
6 questions posted
Top Huffy Cycling Experts
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
View Most Popular
Huffy Cycling
  • Huffy Cycling
Most Popular Question
missing front rim order new one
  • Cycling
