20 Most Recent
Whirlpool 22" Dual Zone 38 Bottle Wine Cellar Chiller Cooler WWC287BLS Questions & Answers
Will not cool to correct temperature as set
check the air exchange under and at back of unit if its to hot or dusty will effect how unit preforms if good and clear possible thermostat or motherboard circuit last would be low on freon
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
How hard is it to add freon to a wine cooler?
Don't attempt it, need special equipment, seek additional quotes but if it's leaking them there is a gas loss issue. You should never need to add gas to a fridge that is sealed in the factory.
Askntechnician why it needs a gas top up? It must be leaking from the pipe work. Adding gas wont solve the problem, you need to find the sauce of the leak to remedy the problem longer term.
4/29/2014 1:49:04 PM •
Whirlpool...
Answered
on Apr 29, 2014
I have a simmons nuflex bed that is fine except the foot wont raise. Massage works on foot, but it just wont lift. No clicking or noises when using the remote
If the foot of your Simmons Nuflex bed will not raise, there may be an issue with the motor or the lift mechanism. Here are a few things you can try to fix the problem:
- Check the remote control: Make sure the remote is properly functioning and the batteries are not dead. Also, check that the foot lift button is not stuck.
- Check the wiring: Check the wiring between the remote, the lift mechanism, and the motor for any frayed or disconnected wires. If you find any damaged wires, they will need to be repaired or replaced.
- Check the lift mechanism: Inspect the lift mechanism and look for any visible damage or debris that may be preventing the foot from raising. Clean the lift mechanism and lubricate it with light oil.
- Check the motor: If the motor is not functioning properly, it may be preventing the foot from raising. If the motor is faulty, it will need to be replaced.
If you are not comfortable with these steps, or if the issue persists after trying them, it may be best to contact Simmons customer support or a professional technician for further assistance. They may ask you to provide your bed's serial number and other information to help troubleshoot the problem.
4/17/2024 2:20:33 AM •
Furniture
Answered
on Apr 17, 2024
What is the best wine cooler in the market?
The NewAir AW-210ED is by far the most successful wine cooler
there is making the best wine cooler overall for the price. The only downfall
is that this specific model doesn't have the highest capacity for the price.
3/27/2024 2:23:42 PM •
Furniture
Answered
on Mar 27, 2024
Which brand provides the best wine coolers?
I don't know but if I needed to find out I would look first at the brands used by commercial establishments that buy for long life and reliability.
While it is fashionable for wine to be overcooled, my father's words often come back to me, "if a drink has to be chilled to taste good, it is poor quality".
White wines and pale beers are traditionally kept in a cellar.
Cellar temperatures are between 45 and 54 F; comparatively mild temperatures that for most of the year in the temperate regions no refrigeration is needed...
3/27/2024 2:20:04 PM •
Furniture
Answered
on Mar 27, 2024
