20 Most Recent Yukon 24021 Monocular Questions & Answers
Define 'clear'.
Is it blurry? Focus the scope or clean the lenses.
Is it distorted? Don't know how to fix. Especially if the lens is cracked/scratched etc.
Is it dark/snowy? Put fresh batteries in.
Do you see black spots in the tube? Don't worry, certain amount of these are quite acceptable.
Anyway: It's a night vision for pete's sake. The picture won't ever be like the one on normal binoculars.
Yukon 24021... | Answered on Mar 07, 2012
these units need a very small amount of light to work at all, They amplify this small amount of light, with no light at all they have nothing to amplify! the infra red is a source of light so it can amplify that, At night they amplify street lighting or moonlight or starlight etc, hope this helps,
Yukon 24021... | Answered on Sep 19, 2011
Don't IR illuminator in the dark room. Turn on a small light in one of the corner; such as, a small light bulb. increase ambient light a little at a time until you can focus. You flooding the dark room with IR illumination which will reflect everywhere in there. This might take care of the fuzziness in the monocular. stewbison
Yukon 24021... | Answered on Aug 20, 2011
Hello, take some switch cleaner--Radio Shack- and spray just a small amount into the switch. Did you installed the battery correctly with the polarity be correct. Does the battery compartment have any type of corrosion? If this does help then there is something else wron with it. stewbison
Yukon 24021... | Answered on Aug 15, 2011
You can download a manual from THIS LINK
The page is the manual in HTML, but you can download a .PDF file from a link at the top. Note that this file is named "5", and your computer won't know what kind of file it is, so you have to rename it "5.pdf" to get your PDF reader to open it.
Yukon 24021... | Answered on Nov 22, 2010
Hello, don't worry about it. It is HV to the image intensifier tube. The battery voltage goes through control circuit then to ccfl inverter (here is were dc voltage is switch on and off and switch dc voltage is step up by toroid coil that has two input and only two out puts). By impulsing the coil with two different switch dc voltage on the input this make the current lag the two different phase voltage by 90 degrees. Here is where the strange noise is coming from. The toroid coil is encased in iron case and if half of this iron case is loose, it makes case vibrate so the noise.
Now, the voltage come out of the toroid coil is switching dc (one could call it AC because that what AC voltage is, it switch between positive to negative) this voltage is about 300 to 900 switching DC voltage. This voltage will be applied to a 1/2 wave voltage multiplier (this voltage multiplier with have anywhere four four stages to 10 stages depend on what the input voltage to multiplier is.
Low the voltage out of the ccfl inverter the more stages the multiplier will have.
Now, the voltage multiplier will double the voltage per stage to need image intensifier tube voltage of 12000 to 45000 volts---DC switching or AC what ever one wants to call it. This voltage will bit you but it doesn't have a lot current associated with it, the current would be in the 10 to 15 ua (micro-amps) 1/10X6 amps.
Now, you know. GB...stewbison
Yukon Optics | Answered on Sep 24, 2011
Check out Crosman site they have many parts an lots of parts fit older an new guns.
Optics | Answered on May 17, 2020
It may be the year 1967. Because I find greener gun number 79259 was made in 1967.
Optics | Answered on May 15, 2020
Trying to figure out how old my Whirlpool washer is Locate your machine's nameplate, which contains both the model and serial numbers. On top-loading Whirlpool washing machines, open the lid and look for the tag at the top rear of the tub. On front-loading washers, the tag is usually inside the door or near the bottom of the left or right side of the cabinet. If the tag is not in one of those places, pull the machine away from the wall and check the rear. Record the serial number with a pencil and paper or take a photograph. Be sure to record the serial number, not the model number. Decode the serial number at an online source like Appliance Cafe or Appliance 411 (links in Resources). Whirlpool serial numbers include a code in the second character for the year the product was built. Before 1990, the character was a number; from 1990 to 2010 the character was a letter. The number sequence started over in 2011.
Optics | Answered on May 13, 2020
https://www.youtube.com/watch?v=s90HADv-mJk
https://www.ebay.com/itm/NEW-BATTERY-CAP-COVER-SCREW-FOR-BUSHNELL-TOUR-V3-OR-V3-SLOPE-GOLF-RANGEFINDER-/264409429458
Optics | Answered on Mar 13, 2020
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Optics | Answered on Feb 20, 2020
Yukon 24021 Monocular Logo
Popular Tags
9 questions posted
Top Yukon Optics Experts
Marvin
Marvin
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
View Most Popular
Yukon Optics
  • Yukon Optics
Most Popular Question
yukon spartan pic not clear light works
  • Optics
