20 Most Recent
InSTEP 12-QE111 Quick N EZ Bike Trailer Questions & Answers
The rubber part inside the arm that connects the
Hi Jason,
I too have this problem, but I also have found the solution. Call Instep at 800-242-6110 and speak with someone in replacement parts. You will want to order the spring coupling. The rubber piece and the spring are sold together. The part costs $4.95 and the total with shipping and handling was a little under $8.00. You should have your part within 3 - 10 business days. Hope this helps. Good luck.
Danielle
[email protected]
How and where do you hook on the bike trailer to
Your bike trailer has a washer looking thing with usually-two holes(one large and one small) The smaller diameter hole mounts to your left side rear axle nut or your quick release wheel nut-meaning, take off the nut or flip thumb tab and unscrew, slip on washer thingy and tighten back down.
The larger diameter hole should be in the downward position like a teardrop, this accepts the bent frame pole from the trailer by use of the spring clip/pin. Slip frame pole into larger hole and lock in with clip and your on your way. ***Just don't forget to attach safety strap from the frame pole to your bike -should the clip ever come undone.(unlikely)
***Do have a bike shop or pro look at the finished hookup if your concerned for safety
I've used my instep safari
Hi kari lyn9...
Remove the front tire and place it under water in a bucket,pail,etc...
Watch where the bubbles are coming from and you will locate your air leak.
Please take time to rate me thumbs up
