20 Most Recent Kenmore 33922 Direct Drive Bagged Upright Vacuum Questions & Answers
The agitator on my wifes Kenmore progressive
Hi
This model of vacuum does not have a belt drive floor roller brush. It has a direct drive motor assemble. So there is no need to access this area. However if you choose to examine the roller brush area, follow the next steps as listed.
The first thing to check is to push the red reset overload protector button on the base assembly. If you have already done that, make sure you have the extension hose properly docked onto the base unit. If you want to get into the lower brush roller assembly you will need to turn the unit over.There are 10 screws on the underside to remove the roller brush bottom cover. Before removing the cover, turn vacuum right side up and release the handle and lower all the way down. Now you should be able to access the roller brush area, to examine for any service issues and air flow blockages. If you do not feel confident repairing this problem yourself, then you can have it repaired by a Sears technician.
Some of these have a resettable circuit breaker, if it has one, push it. There is a motor on the brush roll which could be bad. There also is an on/off switch, it may have a problem. Also may have a switch where the hose goes into, some models have a actuator for the switch, when the hose is pushed in, it actuates the switch so the brush roll motor turns on and stops when you pull the hose out.
Please get back to us if you have further query or else please accept this "particular" solution.
Thanks for contacting fixya.com
9/21/2011 12:51:11 AM • Kenmore 33922... • Answered on Sep 21, 2011
Kenmore upright vac model 33922 - good suction but
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
9/15/2009 11:21:11 AM • Kenmore 33922... • Answered on Sep 15, 2009
Removing and installing the pedal in kenmore upright vacuum cleaner - part no. 8174906; model no. 116.31912100
I don't have specific information on the Kenmore upright vacuum cleaner model number 116.31912100 or the part number 8174906, but I can provide you with general guidance on how to remove and install pedals on some vacuum cleaner models. Keep in mind that procedures may vary between models, so use the following as a general guide:
Removing the Pedal:
  1. Unplug the Vacuum Cleaner: Ensure the vacuum cleaner is unplugged to prevent any electrical accidents.
  2. Turn the Vacuum Cleaner Over: Lay the vacuum cleaner on its back so that you have easy access to the underside.
  3. Locate the Pedal Assembly: Identify the pedal assembly on the underside of the vacuum cleaner. It is usually connected to the height adjustment or other features.
  4. Release Tabs or Screws: Look for tabs or screws securing the pedal assembly in place. Use a screwdriver or the appropriate tool to release these tabs or screws.
  5. Disconnect Linkages: Some pedal assemblies are connected to linkages that control various functions. Disconnect any linkages carefully.
  6. Remove the Pedal Assembly: Once the tabs, screws, and linkages are disconnected, carefully remove the pedal assembly from its housing.
Installing the Pedal:
  1. Position the New Pedal: If you are replacing the pedal, position the new pedal in place.
  2. Reconnect Linkages: If your vacuum cleaner has linkages, reconnect them to the appropriate points on the new pedal assembly.
  3. Secure the Pedal: Use screws or tabs to secure the new pedal assembly in place. Make sure it is securely fastened.
  4. Test the Pedal: Manually operate the pedal to ensure that it moves smoothly and engages the desired function.
  5. Turn the Vacuum Cleaner Upright: Once the pedal is securely in place, turn the vacuum cleaner upright and plug it back in.
If you're uncertain about any steps or encounter difficulties, it's recommended to consult the user manual for your specific model or contact the manufacturer's customer support for assistance. They may provide detailed instructions or guidance tailored to your vacuum cleaner's model and part.
11/19/2023 8:55:35 PM • Kenmore Vacuums • Answered on Nov 19, 2023
Where can I find a kenmore intuition vacuum repair manual
There isn't one! I checked yesterday when I answered your first question. https://www.google.com/search?q=Kenwood+bu4022+service+manual ..
4/7/2023 4:54:00 AM • Kenmore Vacuums • Answered on Apr 07, 2023
Hose assembly model # on 11621714110
The hose assembly model number 11621714110 is a genuine OEM (Original Equipment Manufacturer) part for use with a variety of appliances, including vacuum cleaners and washing machines. This hose assembly may be used to connect various parts of the appliance, such as the pump and the tub, or to connect the appliance to a water source. I hope this information is helpful! Let me know if you have any other questions.
1/4/2023 12:56:42 PM • Kenmore Vacuums • Answered on Jan 04, 2023
What's the cubic square footage of Kenmore 253 28432809
Hi, I'm getting 13.7 cubic feet. To reconfirm, you can call kenmore customer service by dialing 1-844-553-6667. Thank you.
10/12/2022 12:19:08 AM • Kenmore Vacuums • Answered on Oct 12, 2022
2answers
How to replace a circuit board on Kenmore Vacumn model 11621714111
More likely to be a bad connection or brushes on the motor that need replacing. Classic symptom of bad / worn brushes.
8/19/2022 7:50:09 AM • Kenmore Vacuums • Answered on Aug 19, 2022
2answers
Kenmore air cleaner model # 43783252 quits running
Press and hold the filter reset button for 3 seconds to reset the indicator. The control may need to be replaced if it isn't able to reset. [url=http://spacebarcounter.org]Spacebar counter[/url]
8/7/2022 9:32:59 AM • Kenmore Vacuums • Answered on Aug 07, 2022
THe retractable cord of my Kenmore vacuum is stuck Inside, I removed the filter cover, the 2 screws but cannot pull out the cover to access the cord compartment
Thank you very much. I'm up and running again. My retractable cord jump track and got stuck. Thank you thank you. And I did it myself with your directions. Linda
7/26/2022 8:39:04 PM • Kenmore Vacuums • Answered on Jul 26, 2022
2answers
I have a Kenmore canister vacuum. The problem is the the attachment called Pet Powermate doesn't spin very well
It isn’t the belt. Hair builds up in other places besides the brush. The device is made to come apart. Take it apart an clean out both ends on the shaft of roller brush. Remove tangled hair on the shaft and the brushes.
7/5/2022 9:47:40 AM • Kenmore Vacuums • Answered on Jul 05, 2022
Light and brush roll stopped working on Kenmore cannister
There is a connector somewhere in the bottom that will have gotten debris and stuff in it. Unplug the power first then clean it all contact pins that transfer power. Compressed air works the best but the effect can be gained by using a toothpick. Clearing out the connectors should restore the power to the head. If one or the other stops then its a different problem. This seems to be a full failure in the elements of the head that require power. DO NOT WORK ON ANYTHING STILL PLUGGED IN!!!
2/23/2022 4:04:00 PM • Kenmore Vacuums • Answered on Feb 23, 2022
Kenmore 33922 Direct Drive Bagged Upright Vacuum Logo
Popular Tags
4 questions posted
Top Kenmore Vacuums Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Vacuums
  • Kenmore Vacuums
Most Popular Question
agitator wifes kenmore progressive
  • Vacuums
