20 Most Recent
Electric Bicycle Motor, Bike,electric Bicycles ,kits Questions & Answers
Battery won't charge past 12.6 on my Fatman 1000
not car, is electric EV motory cycle or EV moped (it has pedals)
batteries are charged and then load tested with a tool called the same
powered by 1000-watt motor powered by a 48-volt 17AH Samsung battery.
SAMSUNG Lithium Ion 48v
not 12v.
so bad charger, wrong battery put there or battery is bad
we cant see what IS there blind so learn to test the battery first
they fail at 1000 cycles, (short lived they are)
you year told or how old battery is.
any shop can test the battery and charger that came with the bike. let them?
Electric bicycle
Contact the seller for a manual
http://www.omegastores.com/cozybikele.htm
First remove the battery then find someway to support the bike as removing the rear wheel also removes the stand...
Remove the 2 Philips head screws securing the rear mudguard and the 2 on the LHS rear axle cable protection cover & slide the cover off. Disconnect the rear brake. undo the rear axle nuts. Loosen the chain adjusters and slip the chain off. You may also have to deflate the tyre to get it past the mudguard.
I have a GIANT LA FREE SPORT ELECTRIC BIKE. THE
The brake handles have each have a switch button that must be pressed for the motor to work. (Actually what happens is that when you pull the break lever it unpresses the button so the motor won't work against the brakes). Just tape the switch down for the time being. Electric Bikes Northwest and David Hawkins might be able to help you with bike parts. I've gotten some parts from him for my La Free Sport. Very few bike shops know anything about these bikes.
Good Luck!
Dennis
Electric bike cuts out while riding
Couple possibilites. If it is just a matter of your battery clips coming undone, tighten the with pair of pliers then reattach. If it cuts out, then reengages when you start pedaling, either your controler is shot, or you have a ground short on your wheel hub. How long does a charge hold, and how often does it cut out?
Scooter won't go! no power from throttle
check for broken earth wire between hub and plug.i had same problem,i found a second plug half way along loom inside a piece of innertube sealed at ends with plastic tyes, 2ml black wire good luck.
How do I diagnose my aprillia city enjoy that the motor doesn't work anymore
You can download the workshop manual from a few websites, including this one
APRILIA Enjoy City Workshop Manual
I would start by checking and cleaning the battery contacts where they connect the battery to the frame wiring harness near the seat post. The controller requires both 24V and 12V to activate the motor. If the battery gauge is indicating a full battery then it may be that the controller is not getting the 12V feed.
I had to replace the controller in my Aprilia because it had a fault. There is a lot of information on the Aprilia Enjoy models here.
Endless sphere com
