20 Most Recent
Schwinn Joyrider Bike Trailer Red/Black Questions & Answers
For a Shwinn Joyrider PR150
Depending on how old it is, I would send it back on warranty. Do not keep bending it or it will break when you bend it, or worse, while in use. It might just be better to get a new, more durable stroller all together.
What is the wheel circumference of older 1988 AirDyne to use for bike computer to replace Schwinn ergometer?
The wheel circumference of a 1988 Schwinn AirDyne exercise bike may vary depending on the specific model and tire size. To determine the wheel circumference for your bike computer, you'll need to measure it directly. Here's how you can do it:
- Measure the Tire Diameter: Lift the front wheel of the bike off the ground so it's freely spinning. Use a tape measure to measure the diameter of the tire from one side to the other. Make sure you measure the actual tire, not the rim.
- Calculate the Circumference: Once you have the diameter in millimeters, you can calculate the circumference using the formula: Circumference (mm) = ? (pi) x Diameter (mm).
- You can approximate ? as 3.14 for simplicity.
- Convert to Centimeters or Meters: To make it more compatible with most bike computers, you might want to convert the circumference from millimeters to centimeters or meters.
