20 Most Recent Razor Fz 2000 20-Inch Freestyle Bike Questions & Answers
Which way round
you place it between 1and 2 or at the end of the of the sprocket don't worry about that just install it
1/31/2010 7:56:05 AM • Razor Fz 2000... • Answered on Jan 31, 2010
Front fork too narrow to fit tire
sounds like the box may have been squashed. send it back to where you got it from or its not that hard to spread the forks apart by pulling them. used to do this all the time when servicing mountain style bikes that have been thrashed by customers :)
7/8/2009 12:38:43 AM • Razor Fz 2000... • Answered on Jul 08, 2009
2answers
Trying to assemble my bike
the pegs screw onto the threads of the wheel spindle. as for breaks that's a little harder. there are different kinds of breaks, coaster cantilever and disk breaks. ill need more info on the bike model so i can tell you how to adjust the breaks.
5/15/2009 9:00:32 PM • Razor Fz 2000... • Answered on May 15, 2009
I need to know how to attach brake cables to the brakes
there should be (for lack of a better desciption) a round metal "plug" on the end of the brake cable where it attacheds to the lever. it hooks into the lever and there should be an adjustment further down to the caliper to adjust it.
2/27/2009 11:35:26 PM • Razor Fz 2000... • Answered on Feb 27, 2009
Brakes and pegs
There is two ways to put the pegs on.
1. they screw on th the threads of the wheels where it mounts to the frame.
2. If there is just a hole in the peg you have to remove the nut where the tire mounts to the frame put the peg on then put the nut back on the wheel. You will need a long extension for your socket for this method.
Good Luck
12/24/2008 6:04:35 AM • Razor Fz 2000... • Answered on Dec 24, 2008
My razor dirt bike the tire will not spin when its on the ground but spins when it lifted
Here is the link. Watch it.
10/22/2022 8:23:32 PM • Razor Cycling • Answered on Oct 22, 2022
MX 500 Razor Electric Dirt Bike has no power going to the motor.
Question edited for clarity. There are some ideas here. If they don't work, contact Razor Support. https://www.google.com/search?q=mx+500+razor+solenoid ..
1/23/2022 12:51:45 AM • Razor Cycling • Answered on Jan 23, 2022
2answers
Razor mx350 throttle stuck wide open? Is there a fix or does the throttle just need replaced?
SHOULD BE A RETURN SPRING ON IT
11/28/2020 1:06:38 AM • Razor Cycling • Answered on Nov 28, 2020
How do i change a back tire to a escomart metro razor and replace the inner tube without punching a hole in it
I suggest you call a razor customer service person.
2/16/2020 1:44:18 PM • Razor Cycling • Answered on Feb 16, 2020
Razor MX500, new batteries fully charged, suddenly stopped responding. No power, no click, nothing.
Thoughts - No/poor connection between power source and motor Motor failure Only someone with their hands on the bike can fully diagnose.
6/29/2019 5:58:53 PM • Razor Cycling • Answered on Jun 29, 2019
I lost my key to razor mx500 electric dirt bike how can i start it without key?
Hi, You'll need to remove the keyswitch itself & either take it to a locksmith to have a replacement cut from the barrel or replace the entire keyswitch with a compatible replacement unit.!
3/30/2019 3:29:39 PM • Razor Cycling • Answered on Mar 30, 2019
My razor mx 500 dirt bike won’t charge with charger
it is a old charger ?
1/5/2019 8:59:50 AM • Razor Cycling • Answered on Jan 05, 2019
Razor pocket rocket pr200 turns on but dont run what else do I do I buy more parts it still don't work
The off and on switch lights up but will not start.
12/5/2018 5:45:35 AM • Razor Cycling • Answered on Dec 05, 2018
Razor mx 350 powers on but doesn't run what is the cause of this?
Too many possibilities. Do a google search for "Razor mx 350 repair" or "repair electric bike" I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
6/25/2017 3:54:15 PM • Razor Cycling • Answered on Jun 25, 2017
What happens if you blow a fuse on a razor mx500 dirt rocket, would it explain the bike shutting down and not turning back on
http://www.scootercatalog.com/ottrshti.html
This site has everything to check if scooter is not running regarding fuse problems. If you need further help, reach me via phone at https://www.6ya.com/expert/kelley_9a924afdf232bd4d
3/14/2016 6:51:12 AM • Razor Cycling • Answered on Mar 14, 2016
0answers
0answers
0answers
Razor Fz 2000 20-Inch Freestyle Bike Logo
6 questions posted
Top Razor Cycling Experts
ADMIN Eric
ADMIN Eric
vince
ADMIN Andrew
ADMIN Andrew
Are you a Razor Cycling Expert? Answer questions, earn points and help others
View Most Popular
Razor Cycling
  • Razor Cycling
Most Popular Question
brakes pegs
  • Cycling
