20 Most Recent Dahon Matrix Folding Bike 08 size 19 Questions & Answers
I'm trying to locate an extra battery for my ancheer 18.7 folding bike
The battery is most likely not specific only to that bike. Look for a general battery supplier in your area and show them the battery, ask if they can source a replacement. Alternatively measure the size and note the type of connection, then contact an online provider of batteries. I believe the correct specs for the battery are below: Voltage: 350W 36V
  • Charge Voltage: 42V
  • Input Voltage: AC 220V
  • Max Gradient: 15 Degree
  • Battery Capacity: 4.4ah
  • 2 Plugs: US Plug, UK Plug
  • I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
    8/13/2017 2:06:24 AM • Dahon Matrix... • Answered on Aug 13, 2017
    How to raise front stem
    Contact your local bike shop for assistance
    12/2/2014 2:43:36 AM • Dahon Matrix... • Answered on Dec 02, 2014
    0answers
    The fork on my 2003 Dahon Matrix broke
    Hello
    Thank you for using FixYa for your problem
    Check with your local cycle store and see what they can get
    Please rate our solutions and if you still have problems please call back for more ideas to help you
    Thanks
    Richard Scott
    Technical Support
    New Zealand
    12/1/2009 9:45:50 PM • Dahon Matrix... • Answered on Dec 01, 2009
    I have a Dawes Ace folding bike. The frame has
    yes the unit is not fit for the purpose and is in fact dangerous to ride as the seat bolt failure could cause you to loose control items that you should be aware of that may affect your claim 1-- your mass ( folding bikes are designed with a mass limit for the user) 2 --speed limit 3--how you transport the unit At best you can ask for a refund of you money as there is no warranty limit on design faults and there is in consumer law , that there is an expectation that the unit will last well past the warranty period I suggest a talk with a lawyer as to the best way to get a result from the manufacturer
    11/11/2017 1:20:25 AM • Dahon Cycling • Answered on Nov 11, 2017
    How to put a chain back on a dahon bike
    It's really no different than other bikes, but extremely difficult to explain in words, let alone when you include no info as to whether the chain goes through a derailleur, which changes the procedure. It should not be difficult to find someone locally who is able to show you how to do such a basic procedure. I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
    9/19/2016 1:31:02 PM • Dahon Cycling • Answered on Sep 19, 2016
    Is there a diagram or service manual for older Dahon bicycle? Specifically for seat post?
    Contact Dahon. They have a website in countries where their bikes are sold.
    12/8/2015 12:04:54 PM • Dahon Cycling • Answered on Dec 08, 2015
    0answers
    0answers
    Chain slips
    Be the first to answer 5/3/2014 4:04:47 AM • Dahon Cycling • Posted on May 03, 2014Be the first to answer
    0answers
    Change brake calipers
    "Which brake do you have?"
    1/21/2014 1:43:18 AM • Dahon Cycling • Answered on Jan 21, 2014
    Broken gear shift lever
    Here's how to repair a broken shifter toe peg on a motorcycle. The shifter toe peg on my Buell Cyclone was broken off almost completely flush with the shift lever, and the factory used thread locker when they installed it, so the only way to get it out was with an easy out bolt extractor, which is a special drill bit. First I drill a good-sized hole in the middle of the shifter peg bolt, Thia is the most important step. I made sure the hole was in the center of the bolt so I didn't damage the threads on the gear shift lever. Then I put the easy out in the drill, set it to reverse, and it pulled the old broken bolt out. Then I cleaned out the threads in the shift lever and installed the new shifter toe peg using thread locker. Buell recommends using red Loctite. On my Harley Davidson FXR I installed a new shifter toe peg without using thread lock, and it unscrewed itself and fell of after a few weeks of riding. You definitely want to use some type of thread locker. There are no torque specs for putting the new motorcycle shifter toe peg on. Buell just says tighten it until snug. If you have ever crashed your motorcycle, than you've had to deal with this problem from the crash damage. I hope this video helps get you back on the road.
    1/21/2014 1:42:57 AM • Dahon Cycling • Answered on Jan 21, 2014
    2answers
    I dont know how to
    Take the spacers out and cut steerer tube.
    9/30/2013 7:17:41 PM • Dahon Cycling • Answered on Sep 30, 2013
    I have a Dahon Jetstream
    Get the manual and fix it before you die riding it.
    http://us.dahon.com/support/manuals?type=bike&tid=All&title=jetstream&submit.x=53&submit.y=32
    This link is good for overall stuff...
    http://www.parktool.com/blog/repair-help
    6/14/2011 3:37:51 PM • Dahon Cycling • Answered on Jun 14, 2011
    Just bought dahon archer not
    2/23/2011 2:00:37 PM • Dahon Cycling • Answered on Feb 23, 2011
    2answers
    Motor cuts in and out while riding.
    Vehicle also includes panel-mounted fuses for both the motor and control paths. Fuses are mounted on the battery tray for ease of access. FUSES
    Two 30 Amp Slow-Blow fuses configured in parallel in motor circuit path.
    2 Amp Slow-Blow fuse in control circuit path.
    This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
    3/8/2010 12:35:45 AM • Dahon Cycling • Answered on Mar 08, 2010
    I have a Dahon Mu Uno and when I turn the
    The friction is headset pre load, and you need to find a balance. The haynes bike book has a full set up for excatly this. You can find it on Amazon
    6/26/2009 3:03:24 PM • Dahon Cycling • Answered on Jun 26, 2009
    2answers
    What size is the seat post on the Next px 6.0 bicycle?
    The Next PX 6.0 uses a 27.2mm seat post.
    1/1/2024 12:50:08 PM • Cycling • Answered on Jan 01, 2024
    Dahon Matrix Folding Bike 08 size 19 Logo
    4 questions posted
    Top Dahon Cycling Experts
    ADMIN Andrew
    ADMIN Andrew
    Kardoc
    Tony Parsons
    Tony Parsons
    Are you a Dahon Cycling Expert? Answer questions, earn points and help others
    View Most Popular
    Dahon Cycling
    • Dahon Cycling
    Most Popular Question
    trying locate extra battery acheer
    • Cycling
