20 Most Recent
Toshiba Portege 3110CT Notebook Questions & Answers
Reset administrator password
Terry, we need to know which version of Windows you have?
- Try leaving the password blank if you're trying to log on to the actual "Administrator" account. Just press Enter without typing anything when asked for it.
- Enter the password to your account. Often, depending on how Windows was setup on your computer, the primary user (YOU) account will be configured with administrator privileges.
How do i get my toshiba portege to boot from a usb
Before the windows logo comes up, there should be a prompt to go into setup. Usually this involves pressing escape, F2, F8, F10, or F12, depending on the machine.
Once you're in the setup screen (it should look like a stereotypical image from a 1980's computer), there will be an an option titled "Boot". In here you can set the order of bootable devices your computer checks. Set USB to be above your hard drive. There are always instructions on the bottom of the screen on how to change options and navigate around.
I want to install again the WINDOWS 2000
What is the boot order in the BIOS? Set that to 1=FDD 2=CD-ROM 3=HDD
While the PC is still on, put the Windows CD in the drive
Restart the PC, watch the screen for a prompt to boot from cd - press a key
The installation will start, you will need to choose where to install Windows
If you do not need to save any data, format the C: drive and install window there.
Follow the prompts the rest of the way through the installation.
You will need to enter the Windows License code at some point.
It is a good idea to change the regional settings to match your location and how you want the date and time formatted.
Most things should be detected and installed automatically, so you are safe to accept the defaults.
After about 45 minutes you will need to restart the PC and then you should be ready to enjoy Windows 2000.
Be sure to go to Windows Update and install all of the patches.
Good Luck and let me know how it goes.
~ Spoem
Antivirus for low capacity notebook
With those specs, I think you will be hard pressed to find something that won't slow down the system. A lot of Antivirus software now a days requires more RAM than you system has just for real-time scanning.
Sunbelt Software makes a product called Vipre that is relatively new and doesn't consume a lot of RAM. Take a look at that and see if that works for you.
http://www.sunbeltsoftware.com/Home-Home-Office/VIPRE/
If that doesn't work, then I would consider trying something perimeter based like the Dlink SecureSpot device.
http://dlink.com/products/?sec=1&pid=486 That isn't ideal since when you leave you network you will be unprotected, but if you leave this laptop on the same network connection all the time, then this just might work for you.
Graphics are terrible when i play videos
looks to me u need a new video card.....also install the free download MALWAREBYTES....go to google to find download side and let it run full scan...i am sure u have a lot of maleware and other stuff in ur pc....
good luck
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
Toshiba Strata CHSU40A3 no display or tone
If your Toshiba Strata CHSU40A3 phone system is not displaying anything and there is no dial tone, there could be a few reasons for this issue. Here are some troubleshooting steps you can try:
- Check the power source: Make sure the phone system is plugged into a functioning power outlet and the power adapter is working correctly. You may also want to try plugging it into a different outlet to see if that helps.
- Check the connections: Make sure all the cables and cords are connected properly. If the phone is connected to a network, check the network cables as well.
- Reset the phone: Try resetting the phone system by unplugging it from the power source and plugging it back in after a minute. This will help to clear any issues with the phone system.
- Check for any damage: Inspect the phone system for any physical damage, such as cracks or breaks in the casing or any loose components. If you find any damage, the phone system may need to be repaired or replaced.
If none of these troubleshooting steps work, you may need to contact a professional to diagnose and repair the issue with your Toshiba Strata CHSU40A3 phone system.
3/2/2023 5:37:06 PM •
Toshiba...
Answered
on Mar 02, 2023
What happened when Toshiba laptop shows alt+ctrl+del?
More commonly called 'control alt delete' or the 'three finger salute' it has two purposes. On a computer that is running, it brings up Task Manager and other instant settings like Switch User, or log Out. On a computer that is frozen, unresponsive, it does a hard rest and forces the computer to reboot.
2/22/2023 11:34:41 PM •
Toshiba...
Answered
on Feb 22, 2023
