20 Most Recent HP Pavilion dv5-1140us Notebook PC Questions & Answers
How do i completely erase laptop back to factory settings
well HP.com , heard of them. well do what they told you in your free manual.. I guess you lost the OS install disks. Is PC dead now or Password locked or bitlocker enabled?
  1. hp.com
  2. tell them your full service tag info now., they ask.
  3. see you support page matching EXACT model PC
  4. see the manual
  5. RTM read the manual
  6. see chapter called RECOVERY it is all there all ways.
  7. Also if using w10 free upgrade did you , all above is useless.
  8. W10 has and internal reset, told at Microsoft.com
https://support.microsoft.com/en-us/windows/recovery-options-in-windows-31ce2444-7de3-818c-d626-e3b5a3024da5 click line marked RESET your PC and read, HP has 3 recovers for OS reload, 1: the disk in the box day one new. lost? 2: the chapter told you to make the disk and did not day1. 3: some HP have recovery partition but of w10 was he upgade then doing this will regress the PC to w7. or 8 and fails. last , buy w10 and install it or don't buy it and install w10 and run in,no personal setting mode for ever like vast folks so. now. no problem told at all, like PC dead, or HDD is dead and HDD fails S.M.A.R .T tests or the HP diagnostics fail for HDD.
4/13/2022 2:37:01 PM • HP Pavilion... • Answered on Apr 13, 2022
Laptop screen black dv5000z
needs new screen. check out laptopscreens.com
7/26/2013 3:41:57 PM • HP Pavilion... • Answered on Jul 26, 2013
BOOTMGR MISSING HPPAVILION dv8500
Do you have a Windows Recovery Disc? You can use that to repair your boot manager.
3/30/2013 12:00:40 AM • HP Pavilion... • Answered on Mar 30, 2013
3answers
Missing icon (battery icon) on my computer (used to be at bottom)
Please try this : Right click on the taskbar, chose Properties, Then go to the notification Area tab. Under System Icons tick the Power check box. Then apply.
Power icon shall be restored.
6/14/2012 11:48:18 PM • HP Pavilion... • Answered on Jun 14, 2012
0answers
I have an hp pavilion dv5 laptop. When I push the
Yes most all PC's can be "Fixed" it is just a case of parts and money. http://www.retrevo.com/support/HP-DV5-1140-Laptops-manual/id/23082bh634/t/2/
Above your user manual below your service and repair manual.
http://h10032.www1.hp.com/ctg/Manual/c01550108.pdf
Try this below it may work? Above is your user manual, below is your Service and repair manual. Please perform the troubleshooting steps and you should soon be able to isolate and repair your PC.
Ok perform a system restore, press F8 at bootup and choose safe mode desktop, when you are asked if you want the safe mode desktop or system restore, choose restore, and when ask if you want restore or desktop choose restore, restore to a time BEFORE the driver up date and follow instructions and reboot, you should be back where you were.Or start up in safe mode desktop, at desktop, go device manager and "Roll back" the driver. reboot, should be OK
You will have to troubleshoot and find out where the fault is. Here is what I do….. First, check the Power is ON, cable is OK and IN PC, Then open PC up, and remove all power connections from everything EXCEPT the Motherboard Connector.(s) (Remember where they go, draw a diagram etc) Power the computer up, and does it switch on? NO, Then, remove the RAM, does it Boot up? YES Faulty RAM, replace. If it still does NOT then your Power Supply Unit is probably Faulty.(But it may be the motherboard) either way we need to test more with a known good power supply. With know good PSU, plug this one into the Motherboard Connection(s). Does it work, YES. Problem Solved. OK back to Frst: Because it DID go the PSU WAS OK, The MB was OK & the RAM was OK, Now then we plug in each of the other Items, DVD Hard Drive, etc, etc. One-at-a-time, until we find the one that stops the PSU. (It has protection and will "Shutdown in event of a fault") The one that stops the PSU is your culprit, replace whatever it is.
6/10/2010 6:03:04 AM • HP Pavilion... • Answered on Jun 10, 2010
Battery icon
Click Start- search "device"- click device manager- select"+" -ACPI FIXED, Right click, select uninstall -then Restart.
Once restarted, Right click on the taskbar, near the notification icons in the bottom right of the screen. Press properties. At the bottom of the popup are 'System icons', and check the Power icon, and try one last restart.
1/10/2010 5:03:33 AM • HP Pavilion... • Answered on Jan 10, 2010
2answers
I am getting a blue
You cannot see HD because there are no apropriate SATA drivers included in windows XP CD. So you need to create custom windows XP installation CD
To install windows XP in that laptop u will need to create custom windows XP CD, how will you do that:
  1. Download nlite from http://www.nliteos.com/
  2. Download drivers for that laptop
  3. Download service pack 3 for windows XP
  4. Install nlite for windows XP and run
  5. Follow instructions and include SP3 for XP, all the drivers for laptop and create ISO Image
  6. Burn ISO Image
  7. Install Windows XP
  8. Good Luck
11/30/2009 10:05:44 AM • HP Pavilion... • Answered on Nov 30, 2009
Hiya guys,
Ok. Then you can Factory Restore your PC. Doing this, as you very well know, will remove all data and put your PC in a state which it was in when you bought it.
  1. Restart your PC(or turn it on)
  2. Fit F11(or anything that relates to recovery)
  3. Cancel the AutoDetect if it starts up
  4. When you land on the screen with a window that has quite a few options in it, look for one that reads Factory Restore/Recovery.
  5. Choose the option and wait for your PC to be restored.
This option is automated and really quick.
When you log in to your windows again, check if it is possible to make a recovery disc. If so, please get one done. This will help if your recovery partition goes for a toss. Let me know if you need more detail or help. If your problem is resolved, please rate.
11/24/2009 4:38:15 PM • HP Pavilion... • Answered on Nov 24, 2009
2answers
Need a recovery disc for Pavilion dv-5 notebook
Hi:
You most likely have a bad hard drive, and a disk set is not going to help you, though you will need it too.
What you need is a new hard drive, a copy of all the drivers for your laptop, which you can download for free from HP. If HP won't send you a copy of the recovery disk, you can use any OEM copy of the same operating system that your laptop has a sticker for, but you won't have all of your programs.
11/23/2009 11:44:58 PM • HP Pavilion... • Answered on Nov 23, 2009
The battery icon has disappeared
Did you inadvertently move the task bar below the bottom of the screen per chance?
If you are plugged in, the battery icon will be replaced with a plug.
If you need addidtional help with this, let me know. I want to help you
a
9/23/2009 1:33:13 AM • HP Pavilion... • Answered on Sep 23, 2009
3answers
Overheating
It just could be in an enviroment that is too hot. Try using the laptop on a cool flat surface that does not block the vents in any way while in use. If the problem still persists you have 2 options, 1. Upgrade to a better heatsink/fan unit, or 2. Spend $20-30 on one of those laptop cooling pads and use it whenever you use the laptop. Hope this helps.
8/14/2009 4:52:24 PM • HP Pavilion... • Answered on Aug 14, 2009
2answers
HP pavilion dv5 notebook PC screen BLACK !! Help
Make sure you don't have any discs on DVD rom or CD rom. if you don't , uplug comp. from outlet, remove the battery, press and hold power button for about a min..reconnect it to electricity and power back on...If it does not work, respond to me.
8/14/2009 4:50:09 PM • HP Pavilion... • Answered on Aug 14, 2009
Initial start up
Check on the manufacturer website for a driver update for video card.
4/3/2009 11:02:45 PM • HP Pavilion... • Answered on Apr 03, 2009
2answers
HP dv5 heating up
if hp dont have solution for that my advice is buy a laptop cooler or call HP to replace your computer, i was looking for the reviews and there are no negative reviews and hardware heating
3/20/2009 12:06:16 PM • HP Pavilion... • Answered on Mar 20, 2009
Just to add
which one is heating..the battery or the computer itself, you can check in hp web site if your computer and battery are in recall.
3/20/2009 11:37:49 AM • HP Pavilion... • Answered on Mar 20, 2009
I have email error 99999
delete and reinstall your email software.
6/25/2023 8:52:09 PM • HP Pavilion... • Answered on Jun 25, 2023
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
11/30/2022 7:10:30 AM • HP Pavilion... • Answered on Nov 30, 2022
How do i get mywindows keyboard to work
desktop or laptop. ? external Keyboard or internal
6/9/2022 10:54:32 AM • HP Pavilion... • Answered on Jun 09, 2022
HP Pavilion dv5-1140us Notebook PC Logo
Popular Tags
20 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
am getting blue
  • Computers & Internet
