20 Most Recent
Acer Aspire One N270 Notebook Questions & Answers
Mon pc acer aspire one ne marche plus et quand je allume il me enter current password
Quelle version de Windows est install?? Qu'advient-il lorsque vous entrez le mot de passe?
Cliquez sur ce lien (http://tinyurl.com/pyp5wmo) pour obtenir un programme de r?cup?ration de mot de passe gratuit. Installez-le sur un ordinateur de travail faire un fichier de r?cup?ration de cl? USB. Ins?rez usb support de r?cup?ration dans l'ordinateur bris? et r?initialiser les mots de passe tous les deux! si le mot de passe est la raison pour vous de ne pas ?tre en mesure d'utiliser l'ordinateur de la m?thode ci-dessus devrait permettre de r?soudre votre probl?me!
I got this hp laptop but its locked and i dont know the pass word
Ok there is a way to bypass this password BUT only if the BIOS is NOT password protected. Check this by accessing the BIOS (reboot and hold down either F2 or Delete or whatever your laptop requires you to do) then you can see if the password has been enabled or not. To be honest if the BIOS password is enabled you are out of luck I'm afraid unless you have a different password for the BIOS, if not then great, you need to Google (on another PC of course) for a free password bypass program, there are many, then it's basically a case of downloading the program onto a CD or memory stick so you can run the program (usually a Linux code) on the locked laptop. Don't forget when you are in the BIOS looking to see if the password is enabled change the boot order to CD as first in the boot order.
When you Google for this item it will have instructions on how to use it, good luck!!
My webcam wont turn on
usually works from an Instant Messaging app or skype open one of those then go to settings/preferences and adjust audio and videolet me know how that works for you
How to change your acer, aspire one desktop background
Right click on a blank spot on the desktop and click "Personalize". You can then click "Desktop Background" to pick your background.Another option is to find the picture you wish to set as the background, right click on it and click "Set as Desktop Background".
What's your problem?display is too large for
first right click my computer then click properties then click hardware then device manager and the click the + mark on the display adapter and see whether the adapter is marked with yellow question mark if marked so it means you have to install the display drivers if the is no question mark close the window and right click the mouse in the in desktop you will see display properties click settings and increase the screen resolution to 1024x768 then click the advanced click general and in dpi setting make the normal 96dpi and click apply and restart the computer
Blue screen & rebooting
Sounds like you need to reinstall your OS. Warning: you will loose any data on this laptop, and it will be reset to factory settings.
Hold down Alt - F10 right when you turn it on, and it will enter recovery mode. Follow the directions and it will be reset to how it was when you took it out of the box :)
What is the best OS for intel Atom
I have Windows 7 64 bit loaded on mive and I have an 11.5 inch Acer one that has Vista Ultinate on it. They both run great with no issues. If there is not a Windows 7 driver, I used Vista 64 bit drivers that worked fine.
