20 Most Recent Kenmore 44109 / 44102 Side by Side Refrigerator Questions & Answers
0answers
How do you fix the bottom freezer pull out drawer slide out assembly on a Kenmore 795.71019. Cannot get those 2 little black strips with balls on them to stick/stay in assembly and the slide will not
Your refrigerator is a Trio made by LG. Go to page 22-23 in the User Manual=> HERE Does this help answer your question? Sea Breeze
12/16/2013 4:00:38 PM • Kenmore 44109 /... • Answered on Dec 16, 2013
0answers
Refrigerator not cooling
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead? If so, see “It's stopped completely.”
Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
Cooling is poor
For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
The defrost timer
The defrost thermostat (also called the bi-metal switch)
The defrost heater
to check these components .... please refer to my solution in the below link....
http://www.fixya.com/support/t4189238-defroster_not_working_checked_defrost
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
If I've been of Help to you... kindly take a moment to rate this solution.
9/10/2010 6:24:37 AM • Kenmore 44109 /... • Answered on Sep 10, 2010
Freezer side works fine. Fridge side not as cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
6/16/2010 9:15:30 PM • Kenmore 44109 /... • Answered on Jun 16, 2010
How many cubic square feet is our kenmore
25 cubic foot
9/27/2009 4:08:38 PM • Kenmore 44109 /... • Answered on Sep 27, 2009
2answers
Refrigerator
You didn't mention it, but I'll bet there's a "humm" followed by a "click" noise coming from the back of the fridge. Even if you don't hear the noise, the starter on the compressor has failed. One of two things cause this... 1.) A mechanically failed starter. 2.) A seized compressor. If it's the starter only, you are in good shape. If it's #2 and the unit is less than 5 years old, it'll be a warranty claim. If the unit is less than 5 years old... do not attempt the repair yourself. Because, if you do and find the compressor locked up, you have voided your warranty and they will not repair for free. If it's over 5? Install a starter. We need the FULL model number off of your fridge to provide steps on this. It's located on a data tag affixed to the inner fresh food section lining. Most likely near the top on the right. Please post back with these numbers if you require further assistance.
2/7/2009 1:26:07 PM • Kenmore 44109 /... • Answered on Feb 07, 2009
Kenmore refrigerator
HI thanks for the question. the relay is on the compressor. but are the fan, motors running. if not , then its not the relay. it could be in the defrost cycle. but if fans are running. yes the relay. thanks the appliance doc. please rate my answer. thanks
10/6/2008 11:01:16 PM • Kenmore 44109 /... • Answered on Oct 06, 2008
Kenmore SR1087 Freezer Door will not close without lifting
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
check this site out. I have the same problem but I don't have to lift the door to close yet....
8/10/2008 12:00:39 PM • Kenmore 44109 /... • Answered on Aug 10, 2008
2answers
Icemaker
Look at the ice maker and see what position the ejector bar (white bar with fingers that turns and ejects the ice).  Looking at the ice maker from the front (front is white plastic cover) the ejector bar should be in the 2-3 o'clock position .  If it is not then the module is broken.  In this case the module and ice maker thermostat need to be replaced.  If not sure how to do this repair then just buy a new ice maker.  Let me know what you find and we can go further if necessary.  This is the first thing to check.
7/8/2008 9:56:36 PM • Kenmore 44109 /... • Answered on Jul 08, 2008
Kenmore side by side no longer freezing on freezer side and not as cold as it should be on both sides
We had the same thing happened. We called Sears and scheduled a repair. Apparently there is a small electric heater that keeps the coils from freezing up and had to be replaced, about $80, I think. Not sure if that is your problem.
5/27/2008 11:00:16 PM • Kenmore 44109 /... • Answered on May 27, 2008
Kenmore Side-by-side Ice Maker
The only cleaning that can be done is at the inlet valve. If it is anything else you will need to replace it.
5/6/2008 1:24:05 AM • Kenmore 44109 /... • Answered on May 06, 2008
Kenmore Fridge not working
may i suggest you Purchase A premium repair Solution. @ $19.99 or £10.00 G.B.P
One of our technical assistants, will usually have the Answer to your Problem, within the hour.
Mike @ Compurepair.
3/2/2008 8:09:07 PM • Kenmore 44109 /... • Answered on Mar 02, 2008
Kenmore 44109 / 44102 Side by Side Refrigerator Logo
41 questions posted
Top Kenmore Refrigerators Experts
vince
Dennis
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
many cubic square feet our kenmore
  • Refrigerators
