20 Most Recent Kenmore 63074 Top Freezer Refrigerator Questions & Answers
Make sure the drain is cleared ( hot water down the drain ) You may try to adjust your freezer temp just maybe to cold ? Hope this helps
Kenmore 63074... | Answered on Sep 05, 2011
There is a drain trough at that point, for the defrost water, that is clogged.You need to clean it out. It may have iced up.Hope this helped.
Kenmore 63074... | Answered on May 18, 2011
You will have to install a defrost drain heater.
It will help.
Kenmore 63074... | Answered on May 15, 2011
while clearing out the drain, you may have accidentally punctured the evaporator coil. You may be dealing with a sealed system problem, loss of freon.
Kenmore 63074... | Answered on Feb 27, 2011
Hope you would have cleaned fridge and started using immediately. Don't do it.
Power off. Takeslightly wet cloth (dipped in soap water) andclean all portion.And after 5 minutes clean with dry cloth. Keep fridge door opened for minimum 6 hours to allow fresh air passing into fridge compartment. And then place foodsin airtight containers to prevent the transfer of odors. Now close fridge door and plug power.
Hope, it's helpful.
Kenmore 63074... | Answered on Jan 29, 2011
check behind the drawers is there a water tank for water in thew door that would be my first guess
Kenmore 63074... | Answered on May 05, 2009
This IS a common problem - and is due to condensation.
Your Fridge door seal may be dirty or not seating properly - allowing humid air from the outside to enter. The humidity turns into water vapor (condensation) where it meets the cool air coming from the vent.
The solution is not to unplug - but to also clean the gasket well and/or replace it if needed.
Spread the ribs apart to get all the debris, and also wash the metal where it contacts the magnet really well.
A good way to check for an air gap - is to put a flashlight inside the fridge at night, and close the door.
Turn out all the lights in the kitchen... and check for ilght leaking through. If you can see light - the gasket is worn and needs to be replaced.
Thank you for using FixYa - If you need further clarification, please ask me first before moving on to another expert.
Thanks!!
Kenmore 63074... | Answered on Apr 04, 2009
there is a peice sticking out the back wall of the refridgerater compartment just under the top back wall that goes to the defrost drain see if its clear its a square peice also check the drain hose at the back of the unit at the bottom to see if the hose is clear some times they get clogged with alge and wont drain
Kenmore 63074... | Answered on Mar 14, 2009
ok first we need to see if your vent flap up top is bing iced over. you need either a philips screw driver or a 1/4 in nut driver. take off the cover to that flap. this flap is controlled by the electronic strip that controls the temp. on both sides. one question, is their ice build up in the back of the freezer? ok write me back when you get this done. kelly.
Kenmore 63074... | Answered on Dec 22, 2008
Kenmore 63074 Top Freezer Refrigerator Logo
Popular Tags
33 questions posted
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
freezer part
  • Refrigerators
