20 Most Recent
American Standard "Trevi" Deluxe Showerhead AME-1660.115 Questions & Answers
Unit leaking badly. I
follow the instructions below to successfully disassemble your Deluxe Shower head in order to solve this problem:
Unscrew the showerhead from the pipe coming out of the wall. This can be
done by hand but sometimes requires a crescent wrench or large pliers.
The head may be held on with a screw, which you'll have to remove.
Look at the threads inside the showerhead where it screws into the pipe.
There should be a small washer made of plastic or a rubber O-ring.
Replace it if it looks even a little damaged or brittle.
Wrap the showerhead stem with Teflon tape or pipe sealer (pipe dope) to seal the connection.
Remount the showerhead on the stem. Don't overtighten. Hand-tightening should suffice.
Turn the water on and off. Wait several minutes and check for drips or
leaks. If the showerhead is still leaking, you may have problems with
the shower's water-control valve and need to replace the whole shower head.
Keep me posted....
Regards.
5/19/2011 3:43:06 PM •
American...
Answered
on May 19, 2011
Air switch randomly comes on by itself and I have to leave the breaker off
This could be caused by a faulty relay or switch in the control panel. It is best to have a qualified technician inspect the control panel and replace any faulty components. If the issue persists after replacing the faulty components, then it could be a wiring issue and a qualified electrician should be consulted.
2/22/2023 9:40:24 PM •
American...
Answered
on Feb 22, 2023
My American standard champion 4 sings after I flush it, while it I still filling. Then stops when filled.
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
7/12/2019 12:28:16 PM •
American...
Answered
on Jul 12, 2019
