20 Most Recent Kenmore 74889 / 74882 / 74884 Top Freezer Refrigerator Questions & Answers
Is it the cover or the light bulb that isn't coming out? The cover for the 74889 needs to be pushed up and then pull it forward and down. It is hanging by a tab that holds until the angle of the cover is changed to a shallow angle relative to the back of the fridge. The light bulb should unscrew by turning it counterclockwise. If the bulb was previously overtightend, then you may need to use something to improve your grip on the bulb. I sometimes use the plastic jar opener sheets. If the bulb breaks, remove the remainder of the bulb from the socket with pliers (I use needle-nose or similar long straight blade pliers held open to the width of the butlb).
You should unplug the appliance while changing the bulb.
The manual for the Kenmore 74889 is available here: http://www.managemylife.com/mmh/owner_manuals/5899/KENMORE-Top-Mount-Refrigerator-L0411041?brand_name_search=Kenmore+74889 . Other Kenmore manuals can be found by using the search engine here: http://www.managemylife.com/mmh/owner_manuals .
I hope this helps.
Kenmore 74889 /... | Answered on Mar 21, 2011
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Kenmore 74889 /... | Answered on Sep 13, 2010
Might try contacting Sears in the United States or Canada to see if they can assist in any way:
https://www.manualslib.com/manual/556712/Kenmore-253-4474.html?page=21#manual
Kenmore... | Answered on Jun 27, 2020
Water Treatment Accessories & Filter Parts ' Kenmore
www.kenmore.com > air-and-water-treatment > water-filter-systems
Water filter parts can regulate the taste and odor of water delivered to your home. Improve the quality of your water with Kenmore water treatment accessories. Missing: spares โ€Ž' Must include: spares
Kenmore elite refrigerator parts ' Sears Parts Direct
www.searspartsdirect.com > combo > kenmore-elite-refrigerator-parts
Kenmore elite refrigerator parts - manufacturer-approved parts for a proper fit ... Most Kenmore Elite refrigerators use a water filter to remove contaminants from ... Frigidaire Dishwasher Spare Parts, Craftsman Air compressor Spare Parts, ... โ€ŽKenmore Elite 79579043313 ... ยท โ€ŽKenmore Elite 79573139410 ...
Kenmore refrigerator parts ' Sears Parts Direct
www.searspartsdirect.com > combo > kenmore-refrigerator-parts
When you need to replace the water filter in your refrigerator, Sears PartsDirect has the genuine Kenmore water filter that fits your model. Kenmore water filters ...
Kenmore... | Answered on Jun 14, 2020
If the freezer is located above the fridge, the air from the freezer drops into the fridge to create the cooling in the fridge. So what I would look for is a blocked vent from the freezer to the fridge, which is usually located on the top and or back of the fridge inside of cores. You can get a frost or ice build up in there and block the air flow to the fridge, that is usuall the problem. I would also heck the dial for temp control in the fridge, I know my kids have changed it before on me.
Kenmore... | Answered on Jun 13, 2020
Kenmore... | Answered on May 06, 2020
I cannot locate any model number with what you have provided. Schematics for boards in appliances are very difficult to obtain. They are proprietary. You may end up having to test each component with test equipment. There are several type of test gear that you may need.
Kenmore... | Answered on Apr 19, 2020
Hello larry! You can clean the drain right inside of your freezer.
Here's some video tutorial on how to clean from above .
https://youtu.be/Pc5He1bImUQ
Kenmore... | Answered on Apr 13, 2020
Som relay or switch cudda gut fried..unplug it for fewmin n see if anything clears..if not ull need tests done by atech. If its an old unit umay b bettr off replacin cause itll b anothr part down road$
if I could see it perhaps I could tell however have never seen one
Kenmore... | Answered on Mar 23, 2020
Check to see if the unit it level, sounds like it is not. The unit may be like a Samsung model that has this issue. The tray that catches the ice is supposed to be slanted towards the back of the unit.
Kenmore... | Answered on Mar 21, 2020
Kenmore 74889 / 74882 / 74884 Top Freezer Refrigerator Logo
2 questions posted
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
change
  • Refrigerators
