20 Most Recent Kenmore 63822 / 63824 Bottom Freezer Refrigerator Questions & Answers
The number you listed is an item number used by the store and is not a model#.. The model sticker is usually located on the right wall inside the fridge and can sometimes be on the ceiling as well as under a drawer if it is a built in. They look like this and I would need the complete number to look at what you have.
I can say that if it is loud and you do not see anything around the fan blades.. You unplug it then plug back in, watch the fans start and a minute later is when it gets loud then that is the compressor. It is a very expensive fix and is rarely worth it.
Kenmore 63822 /... | Answered on Jan 27, 2018
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
Kenmore 63822 /... | Answered on Dec 27, 2015
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
There are many people that have this problem and are searching for answers as to what to do and what could be causing this problem. It seems to be weird that the freezer is working fine and the fridge side is not. Why would the coldest side be good and the warmer side not?
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it’s own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Take care.
Kenmore 63822 /... | Answered on Jul 18, 2010
uve probably got a freon leak check to see if compressor is running and fans inside are blowing if so then u probably have a freon leak
Kenmore 63822 /... | Answered on Feb 24, 2010
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Kenmore 63822 /... | Answered on Dec 01, 2009
the garage kit, if even available for your unit, works pretty well, but your right in extreme colds your outta luck, other then buying a refrig designed to work in garage, yoll need to either insualte and heat garage, or wait till spring sorry.
Kenmore 63822 /... | Answered on Jan 11, 2009
Could be a number of reasons
short of gas
evaporator blocked with ice
defrost thermostat not working
defrost heater not working
fan not working
Kenmore... | Answered on Sep 19, 2020
Have you checked the air passage ways from the freezer to the main box. They may be blocked with ice or they could be blocked with items covering them up. Are your cold controls set so that freezer air is directed into the box? It is possible that they maybe set to keep all the cold air in the freezer if that is set to coldest for the freezer, When the controls are adjusted it can take up to 24 hours to really see a difference. There is also a vane type of control operated by a small motor to direct the air from the freezer to the box on some models that may have failed.
Kenmore... | Answered on Sep 13, 2020
Make sure that the condenser is clean and that the fan turns freely. Look for plastic bags block the air from the condenser.
Kenmore... | Answered on Sep 05, 2020
Try this site for your manual.
http://www.manualsonline.com/
Kenmore... | Answered on Sep 04, 2020
Kenmore 63822 / 63824 Bottom Freezer Refrigerator Logo
15 questions posted
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
freezer works but refrigerator not cold
  • Refrigerators
