20 Most Recent Jaeger-lecoultre Master Compressor Memovox 1708170 Wrist Watch Questions & Answers
The date changes around midnight and you can usually advance the date by going past midnight until the date changes and then turning the watch backward to a time shortly before midnight and then winding it forward again.
How far back you need to go you will have to find by experiment but it should not be very far.
Jaeger-lecoultre... | Answered on Jun 09, 2011
mcdevito75 here, Sounds like you need the watch serviced, specially if not so in 2 years. Check the repair service directory here at Fix Ya, bottom of the page click on repair service directory then watches.
Jaeger-lecoultre... | Answered on Jun 25, 2010
mcdevito75 here, It does seem to be a hard way to set the date. I would imagine to you have stem and not buttons, Try this slip your fingernail just under the stem (winder) and lift the stem to it"s first position, now turn the stem either toward or away from you to change the date easily.
Jaeger-lecoultre... | Answered on Jun 21, 2010
Your question was cut off please explain your problem further Don
Jaeger-lecoultre... | Answered on Sep 13, 2007
Do you have the model number. That would help you to make some speculations or comparing the recent cost or repair.
Thanks!!
Jaeger-lecoultre... | Answered on Sep 19, 2010
It might be worth having the back of the watch removed to see if there is anything engraved on the movement.
You might find that cleaning the watch gets is going, although the advice of the watch repairer should be asked for on this, as it might be very worn and in need of new parts which are unlikely to be available.
If it works and there is information on the movement, you might be able to get some information on the watch from the maker. Visit their web site (www.jaeger-lecoultre.com/) and make an inquiry, giving them all the information that you have.
An interesting problem!
Good luck.
Jaeger-lecoultre... | Answered on Jan 24, 2010
If you can provide over here the picture of the watch, that would be easy to identify the problem and fix.
Let me know
Jaeger-lecoultre... | Answered on Sep 08, 2009
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
Watches | Answered 15 hours ago
this is a repair help website. we dont sell buy or value anything here
Watches | Answered on May 26, 2020
To change the clock format, visit the General section of Momentum's Settings ??, scroll down to the Clock Format option and then click 12 hour or 24 hour to the right of it. When you switch to the 12-hour format, the AM/PM unit will display for a moment and then fade away to keep the interface clean.
https://get.momentumdash.help/hc/en-us/articles/360022896993-How-can-I-change-the-clock-format-12-hour-24-hour-
https://www.youtube.com/watch?v=VfthmmTM7Oo
Watches | Answered on May 21, 2020
a jewelry store or a clock repair store
Watches | Answered on May 17, 2020
https://www.youtube.com/watch?v=Hj1lKEULXAI
Watches | Answered on May 13, 2020
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Watches | Answered on May 09, 2020
Jaeger-lecoultre Master Compressor Memovox 1708170 Wrist Watch Logo
11 questions posted
Top Jaeger-lecoultre Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Jaeger-lecoultre Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Jaeger-lecoultre Watches
Most Popular Question
memovox running fast got now about month
  • Watches
