20 Most Recent Kenmore 24.8 cu. ft. Trio French Door Bottom Freezer Refrigerator Questions & Answers
can you tell the compressor is running? It's hidden in back or bottom. If you are lucky it may be a bad thermostat, or possibly a defrost timer that has failed. To eliminate bad thermostat, adjust the temperature up and down to see if that is the problem. If you can determine that the compressor is running you may have a freon or refrigerant leak and will need to call a service technician.
Kenmore 24.8 cu.... • Answered on Feb 13, 2015
the water actuator switch could be bad or the arm broken. The water line could be frozen in the door or the reservoir ion the fresh food compartment. the water valve in back could be bad.
Kenmore 24.8 cu.... • Answered on Jul 16, 2014
it probably needs new fans in the freezer... check to see if they are blowing, you can usually hear them when you open the freezer door
Kenmore 24.8 cu.... • Answered on Sep 27, 2012
No!!!
Not if you do not know eactly hwat you are doing... and if there is ice and water in the door it is even harder...
heatman101
Kenmore 24.8 cu.... • Answered on Jan 29, 2011
bad/dirty door seals allowing fresh moist air in.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Kenmore 24.8 cu.... • Answered on Sep 30, 2010
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Kenmore 24.8 cu.... • Answered on Sep 11, 2010
Stay away. If it does need freon it means it has a leak somewhere in the sealed system. That can be a very expensive fix. Who diagnosed the problem? May be other issues. If your looking for used go to an appliance dealer to get at least a 30 day warranty. I would not reccomend buying anything that has not been repaired first.
Kenmore 24.8 cu.... • Answered on Sep 04, 2010
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Kenmore 24.8 cu.... • Answered on Aug 20, 2010
Hello and Welcome to FixYa!
The dripping water could be from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit.... The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. Another cause may be the refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something like that, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the water disappears the problem is solved.
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Kenmore 24.8 cu.... • Answered on Aug 18, 2010
There should be one or more hex shaped keys within the door handle, usually on the side or bottom of the handle. Simply loosen them up and the handle should pop right off.
Kenmore 24.8 cu.... • Answered on Jun 14, 2010
Refrigerators Logo
Popular Tags
34 questions posted
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
ice maker overflows freezes bottom
  • Refrigerators
