bpat, Im guessing that your model number begins with 106, If so it's built by Whirlpool. Look at your owners manual and see if it mentions a warranty on the liner. Some models carried a 10 year warranty against cracking. If not, there are some kits available out there to patch cracks but it's not the greatest looking deal. Catriver...post back
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Coldspot 106. Model
This model refrigerator is a relatively small refrigerator. It is a Freezer on top model, and Sears documents lists this unit at 18.1 cu ft. I hope that answers your question about capacity.
I'm glad I could help. If you need anything else, just let me know.
In reality, when you buy a replacement, you buy by dimensions to fit the space not cubic feet of the old one. Go to Home Depot armed with a tape measure.
Turn it off by removing the wall plug for 10 minutes. This will do a power rest to the control electronics. This is a bottom mounted freezer, so cold air for the fridge is vented upwards by a fan. Make sure it is running and there are no ice blockages. Strangely they call the fan in the fridge an
Refrigerator Evaporator Fan Motor. The part is obsolete anyway.
If it normally says 4 for the fridge, that would be 4 degrees Centigrade, which means the freezer should show minus 18'C. Or 36'F Fridge / 0' F Freezer/
This shows all the parts.
https://www.searspartsdirect.com/model/3tradtge4f-000582/kenmore-79575004401-bottom-mount-refrigerator-parts
Not normally a flapper. There is a trap on the rear outside cabinet just below the level of the freezer. Remove it and soak in hot water and bleach for 20 minutes, then flush all the debris out, shake it dry and reinstall.
Put some Vaseline on the O-Ring to help it slide into place. Make sure it is properly inserted at the beginning.
If the filter is located inside the refrigerator:
Turn off the ice maker.
Push the eject button.
Pull the filter out of the housing.
Push the new filter into the housing until it clicks.
Turn on the ice maker.
Run 2 gallons of water through the water dispenser to purge air and residue.
Kenmore appliance model numbers have a three digit prefix (106 in this case) for the manufacturer. The rest of the model number indicates a lot of the specifics for the refrigerator. The third digit is the second group indicates the capacity. This fridge is a 22 cubic foot model (or slightly smaller).
I hope this helps.
From here on Fixya
https://www.fixya.com/support/t26563238-many_cubic_feet_kenmore_coldspot
Hello Linda. This should be below my Answer rather than being a new Question. This post has no context to the previous question and my answer. I just happened to see it, but if you clicked Comment under my answer, I would get a notification and come back to help. If I hadn't seen it and someone had answered it with 'not sure what you mean', it would have vanished off the Homepage as Solved and I would never have seen it.
I was just copying Cindy Wells answer, but yes, it is the total cubic feet of both the refrigerator and freezer combined.
https://www.fixya.com/users/linda-adamski
