20 Most Recent Kenmore 56562 / 56564 / 565 / 6656569 Side by Side Refrigerator Questions & Answers
the inlet water valve has a screen on the inlet in the valve which is probably clogged - replace the inlet water valve with a new one, install a ice maker water filter in the water line feeding the ice maker!
Kenmore 56562 /... | Answered on Jan 16, 2018
the problem is gas build up in your fridge
use arm and hammer baking soda boxes for the fridge.
that will help a lot
Kenmore 56562 /... | Answered on Feb 22, 2016
Your most likely cause is the $170 control board. It is the only thing that I know of that can change the temperature automatically. Please rate this post.
Kenmore 56562 /... | Answered on Dec 14, 2009
Check holes in spray bars, and clean as necessary. Those holes on an angle are the ones that propel the bars.
Kenmore 56562 /... | Answered on Sep 19, 2009
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Kenmore 56562 /... | Answered on Jul 01, 2009
Hi thanks for the question It looks like you have a problem with your water valve At the back youwill see a water valve with 2 solenoids one could be faultyto check this reverse the wires on the valve and push the water disp if water goes into ice maker you solenoidis ok if it does not go in replace valve
Kenmore 56562 /... | Answered on Dec 16, 2008
The heater only has two wires. They are located in the places where the new item plugs in. If the timer is bad, generally, you should have the schematic. Look on the back of the fridge or behind the motor cover.
Kenmore 56562 /... | Answered on Nov 14, 2008
YOU NEED A REPAIRMAN TO FIX IT
Kenmore... | Answered on Nov 14, 2020
Sounds like the freezer drain is stopped up. Clear the ice with a hair dryer, find the drain hole, clear it compressed air.
Kenmore... | Answered on Oct 17, 2020
It could be because the door is open.
mostly the fan motor does not run then so try closing he door well. There are numerous reasons, It could also be caused by frozen evaporator coils, leaky refrigerator hoses, a heavy crowded freezer, a broken or malfunctioning thermostat or a clogged defrost drain.
Kenmore... | Answered on Sep 19, 2020
Kenmore 56562 / 56564 / 565 / 6656569 Side by Side Refrigerator Logo
14 questions posted
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
kenmore refrigerator control box temp
  • Refrigerators
