20 Most Recent Moen L3175 Chrome Legend Single Handle Posi-Temp Pressure Balanced Shower O Questions & Answers
On the underside of the handle there will be a set screw, usually an allen key that will need to be loosened. Once you do this the handle will pull right off. The moen website shows an exploded .pdf view. I found your model by searching with the model name, Legend. http://www.moen.ca/shared/pdf/l3175pt.pdf
Moen L3175... | Answered on Jul 24, 2010
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
Moen L3175... | Answered on May 10, 2010
replace cartridge
Moen Home | Answered on Jul 14, 2020
https://www.google.com suggests the following link:
https://www.hunker.com/12267493/how-to-clean-a-moen-shower-head
Quoting from link above:
How to Clean a Moen Shower Head By BRENDAN O'BRIEN
Photos.com/Getty
images
Taking a shower could be hazardous to your health if you do not properly and regularly clean your shower head. According to a study at the University of Colorado at Bolder, your shower head may contain harmful bacteria. But not to worry, with some old-fashion vinegar, elbow grease and about 45 minutes, you can take a shower with peace of mind. Clean a Moen shower head while it is still attached, or remove it before cleaning.
  • Volume 0%Detached Shower Head
    Step 1
    Remove the Moen shower head. This may require pliers or vice grips. If you use tools, place a towel or rag over the shower head to protect it from scratches and dents.
    Step 2
    Remove the cover of the shower head, if there is one. The cover may twist or snap off. Do not force it if it seems stuck. This is not a requirement. You can clean the shower head with still attached.
    Step 3
    Warm the white vinegar on your stove. Do not boil the vinegar. Gauge how much vinegar you will need by the size of your Moen shower head. You need to fully submerge the shower head in the vinegar.
    Step 4
    Pour the warm white vinegar in a bowl or bucket. Place the shower head in the bowl and submerge it in the white vinegar. Let it soak for 15 to 20 minutes.
    Step 5
    Clear the holes in the shower head with a paperclip or thin wire. Clear all of the debris from the holes. Dunk and rinse the shower head back in the vinegar.
    Step 6
    Rinse the shower head and cover with hot water. Re-install the Moen shower head and cover. Test the shower to make sure you have re-installed it properly. Attached Shower Head
    Step 1
    Fill a plastic bag with warm white vinegar.
    Step 2
    Place the bag over the Moen shower head so it is complete submerged in the warm vinegar. Place a rubber band or piece of tape around the stem, securing the bag to the shower head.
    Step 3
    Remove after 15 to 20 minutes. Take an old toothbrush and scrub off the mineral deposits and debris. Rinse off the shower head thoroughly with hot water and a wet cloth. Brendan O'Brien
Moen Home | Answered on Jul 07, 2020
It is a feature to save water on a handbasin, but there is an insert or a different cartridge that you can fit for filling a bath. Contact Moen.
Moen Contact Us ' Moen
https://www.moen.ca > customer-support > contact-us
Contact Us. ... 1-800-465-6130. OR. telephone icon Email. Moen will respond to your email within 48 hours. Send an Email ... ‎Warranty Information · ‎Installation Help · ‎FAQs
Moen Home | Answered on Nov 16, 2019
remove the head remove restrictor add a gasket reconnect
Moen Home | Answered on Oct 29, 2019
Sounds like your cartridge is not properly seated and also may not be aligned properly.
Remove it and apply a thin coating of plumbers grease to the cartridge and then work it back into it's position rotating back and forth to insure it is going down all the way.
HERES A MECHANICS TRICK IF YOU HAVE STANDARD AND METRIC WRENCHES TRY BOTH AND MAYBE ONE OR THE OTHER WILL FIT BETTER...SOMETIMES A BIT O HEAT WORKS HERE ALSO... OH AND IF YOU HAVE AIR IN A CAN TURN IT UPSIDE DOWN AND HIT THE HEAD OF THE SREW TO FREEZE AND MAKE IT SHRINK TO SHOCK IT...IT SHOULD COME OUT...BARRING ALL THAT YOULL HAVE TO DRILL IT
Moen Home | Answered on Sep 14, 2019
Change shower. if u want repair open the controller and replace rubber washel.
Moen Home | Answered on May 14, 2019
Moen posi-temp cartridge. 1222/1222B
-or-
Moen 96988 Cartridge Repair Kit Posi-Temp 1 Handle tub/shower
https://www.moen.com/shared/docs/exploded-parts-views/82000pt.pdf
Best to have the Moen Cartridge Puller.
Moen Home | Answered on May 01, 2019
DUH HOW DOES ANY CARTRIDGE WORK ?
Moen Home | Answered on Jan 29, 2019
http://www.moen.com/shared/docs/instruction-sheets/ins10040.pdf
Moen Home | Answered on Jan 04, 2019
Just buy a backflow preventer and install it in-between the pipe coming out of the wall and the shower head. Most (all?) shower heads have 1/2? standard pipe thread. Home Depot sells a backflow preventer with 1/2? standard pipe thread for $6.97.
Good luck and hope this helps.
Moen Home | Answered on Nov 14, 2018
you go to moens website and find the one you have and download a manual for it.
Moen Home | Answered on Nov 10, 2018
Moen L3175 Chrome Legend Single Handle Posi-Temp Pressure Balanced Shower O Logo
3 questions posted
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
View Most Popular
Moen Home
  • Moen Home
Most Popular Question
remove handle l3175
  • Home
