20 Most Recent Saeco Stratos Coffee Maker, Espresso Machine Questions & Answers
www.coffeemachinemanual.com/saeco-stratos
You might what to see if this is of any help.
Saeco Stratos... | Answered on Jun 24, 2014
First run a Descale cycle from the menu (this will take several hours/overnight). Then hold the steam button for five seconds to reset the code. Good Luck!
Saeco Stratos... | Answered on May 23, 2014
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Saeco Stratos... | Answered on Apr 19, 2014
I think it means to fill the water container and then run it all through.
Saeco Stratos... | Answered on Sep 13, 2012
Hi You need to change your language in the menu. Push and hold the menu button. When it changes in the window, use the up or down arrow button to move the asterisk (*) until you come to a window that has something like "lingua, or spreka", and then push the menu button again. Use the up arrow to scroll to "English". When you have the asterisk (*) in front of English, push the menu button again. You have selected English and then you can push the escape button to exit. Some machines have exit in the scroll bar, so it depends on your machine.
Saeco Stratos... | Answered on Jun 18, 2011
Hi
When you are done steaming, just press the water button and open the steam valve again. This will purge the steam and cool the boiler back down. When it is cool enough the display will change back to "product ready for use". Have something under the steam wand as this is where the steam and water will come out.
Saeco Stratos... | Answered on May 11, 2011
HI
Your spout is getting clogged with residule coffee. There is a screw pin behind the spout that you can loosen and remove the spout to clean. There will be a long tube attached to the spout dispenser.
When you put it back in the tube slips on the brew units outlet before you tighten the screw down.
Saeco Stratos... | Answered on Jan 27, 2011
Saeco Stratos Coffee Maker, Espresso Machine Logo
40 questions posted
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Saeco Coffee Makers & Espresso...
  • Saeco Coffee Makers & Espresso...
Most Popular Question
decalcify jura
  • Coffee Makers & Espresso Machines
