20 Most Recent Kohler K-T12007-4s-BV Brushed Bronze Fairfax Single Handle RiteTemp Tub and Questions & Answers
Sounds like the cartridge inside the valve body may need replacing.
Kohler... | Answered on Oct 26, 2010
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
Kohler... | Answered on May 17, 2010
Are you sure it's not just that the shower heads are getting dirty from calcium build up, thus reducing the diameter of the holes in the head, which will in turn cause spray to come out at higher pressure. ( same idea as holding your thumb over the end of a garden hose) Try removing and either replacing head, or soak it overnight in C.L.R (available at any hardware store.) and clean it good and try it again.
Kohler... | Answered on May 03, 2010
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Kohler... | Answered on Mar 24, 2010
The device which directs the water up or down is called the diverter. Your diverter is not fully up or fully down. Rather forcefully push and pull the diverter a few times and your problem may be solved. good luck.
Kohler... | Answered on Jan 25, 2009
THEN DO NOT TURN IT VALVES OPEN SO FAR .THINK
Kohler Home | Answered on Mar 25, 2020
Contact Kohler service department for a free replacement
Bidets ' Bathroom ' KOHLER
www.us.kohler.com > browse > bathroom-bidets
Browse KOHLER bidets. Designed to complement the styles of KOHLER toilets and faucets. ... Puretide™ Quiet-Close™ Elongated manual bidet toilet seat.
Intelligent Toilets and Cleansing Seats ' Bathroom ' KOHLER
www.us.kohler.com > article > CNT121600001
KOHLER intelligent toilets sense your approach, open automatically and close and flush when you leave. Or a heated seat that nestles you in luxurious warmth?
Kohler Home | Answered on Feb 20, 2020
We had a problem with phantom flushing. Call Kholer. They will send redesigned battery holder and top of flush unit for free. Seems to have fixed the issue.
Kohler Home | Answered on Jan 09, 2020
The only batteries are in the docking station. If the remote is attached to the docking station, take that off and set it aside. Next, carefully lift the docking station up and out from the mounting bracket. Look at the back of the docking station, push the two tabs outwards (away from each other) simultaneously to open the battery compartment cover. Replace the batteries (4 AAs) in the correct orientation. Reinstall the cover. Then replace the docking station on the mounting bracket and put the remote back on the dock if desired.
These directions are shown in the Homeowner's Guide (without the service parts) available on the product page: https://www.us.kohler.com/us/veil-intelligent-comfort-height-skirted-one-piece-elongated-dual-flush-toilet/productDetail/toilets/1120267.htm . Scroll down to the Installation section to find the link to the document. The current link to this guide is https://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1226974_5.pdf .
I hope this helps.
Kohler Home | Answered on Jan 05, 2020
Request the parts list from Kohler.
Kohler Home | Answered on Dec 08, 2019
First, identify the style of your quick connect hose.
See the steps on this Kohler Fawcet Link for disconnecting your pull-out kitchen faucet quick connect hose. Follow this link: https://support.kohler.com/hc/en-us/articles/360001798834-Disconnect-Quick-Connect-Pull-Out-Kitchen-Faucet-Hoses
Make sure the water valves are closed and the water pressure is relieved before attempting to service your kitchen taps.
Kohler Home | Answered on Oct 12, 2019
The brand of toilet doesn't matter. You need a product that cuts calcium and lime. It may take some soaking and scrubbing. Once you get it clean, use the product regularly.
CLR makes a line of products:
https://clrbrands.com/en-US/Products/CLR-Household/CLR-Calcium-Lime-Rust-Remover
Kohler Home | Answered on May 10, 2019
I don't know this specific tub, but here's the pictoral. The button (90105) should come out of its base, held by friction of O ring. This should allow you to disconnect the pressure line. If you are looking to replace the complete assembly, likely you will need a basin wrench to reach nut (65157).
kohler1-ggmuzyqdnvlyrlfigj0gxfoh-4-0.png Here are links to Kohler, specific to this tub.
https://www.us.kohler.com/us/catalog/svg_viewer.jsp?productId=415928&diagram=3 https://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1010564_5.pdf
Kohler Home | Answered on Mar 18, 2019
you have kids??? theres probably something large in the trap
Kohler Home | Answered on Mar 10, 2019
Smart-a$$ answer is to find an old 3 gallon pot in a salvage place. Best answer is to fiddle with the chain that goes from the handle to the flush flapper and see if adjusting its length makes a difference. If it's too short it might result in letting the flapper closing too soon and allowing your deposit to remain.
Kohler Home | Answered on Mar 01, 2019
Kohler K-T12007-4s-BV Brushed Bronze Fairfax Single Handle RiteTemp Tub and Logo
6 questions posted
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
when turning on the shower faucet there
  • Home
