20 Most Recent Kenmore 13485 Wine Cooler Questions & Answers
Troubleshooting kenmore wine cellar model
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/27/2011 9:33:05 PM • Kenmore 13485... • Answered on Sep 27, 2011
Our kenmore wine cooler started
I don't know how it is leaking water, it isn't hooked up to a water supply. better start looking for the actual source of the water
3/23/2011 10:41:49 PM • Kenmore 13485... • Answered on Mar 23, 2011
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
7/22/2010 10:00:43 AM • Kenmore 13485... • Answered on Jul 22, 2010
Clearance??
hi you need at least 3 inchs clearance from the back ribs to the wall for good ventilation if there is no ventilation back there you will need to do 1 if to whole room is hot then you can install a fan that will cool down the heat from ribs good luck
2/26/2006 12:23:05 PM • Kenmore 13485... • Answered on Feb 26, 2006
0answers
0answers
How can I ensure the quality of a sofa when ordering online in the UK?
Your budget determines how much quality the sofa has
4/18/2024 10:12:05 AM • Furniture • Answered on Apr 18, 2024
I have a simmons nuflex bed that is fine except the foot wont raise. Massage works on foot, but it just wont lift. No clicking or noises when using the remote
If the foot of your Simmons Nuflex bed will not raise, there may be an issue with the motor or the lift mechanism. Here are a few things you can try to fix the problem:
  1. Check the remote control: Make sure the remote is properly functioning and the batteries are not dead. Also, check that the foot lift button is not stuck.
  2. Check the wiring: Check the wiring between the remote, the lift mechanism, and the motor for any frayed or disconnected wires. If you find any damaged wires, they will need to be repaired or replaced.
  3. Check the lift mechanism: Inspect the lift mechanism and look for any visible damage or debris that may be preventing the foot from raising. Clean the lift mechanism and lubricate it with light oil.
  4. Check the motor: If the motor is not functioning properly, it may be preventing the foot from raising. If the motor is faulty, it will need to be replaced.
If you are not comfortable with these steps, or if the issue persists after trying them, it may be best to contact Simmons customer support or a professional technician for further assistance. They may ask you to provide your bed's serial number and other information to help troubleshoot the problem.
4/17/2024 2:20:33 AM • Furniture • Answered on Apr 17, 2024
Colorado metal 4 seater dining set with parasol assembly instructions please?
Question edited to remove Funky-Dash-Use- :>D Lots of pretty pictures, but no instructions. If it is new, reach out to the store or the online seller. It looks pretty easy by looking at the pictures and zooming in on the B&Q website. Lay all the parts out. https://www.google.com/search?q=Colorado+metal+4+seater+dining+set+with+parasol+assembly+instructions ..
4/14/2024 5:11:05 PM • Furniture • Answered on Apr 14, 2024
Brand new Koolatron 8 bottle wine cellar displays only in C degrees. Can't change to temp F. The button for C/F is the same as the light button. Light on/off works....
Touch the button to turn the light on, press and hold to 4 seconds. display from Celcius to Fahrenheit. Touch once to turn the interior light on or off. To switch between Celcius and Fahrenheit, hold button for 4 seconds.
DELUXE WINE CELLAR
4/6/2024 10:53:12 PM • Furniture • Answered on Apr 06, 2024
PC wining light indicates problem
Is this Wong Chan with his Sony Vaio question? Makes no sense 'wining'? 'whining' light, 'winning' light, still no sense. Posted to 'Furniture' category? All questions need 'make model (what it is)' first 3 words. https://www.google.com/search?q=Sony+Vaio+PCG-9S1L+owner+manual Warning Lights? https://www.google.com/search?q=Sony+Vaio+PCG-9S1L+wining+light+indicates+problem ..
4/6/2024 7:08:37 PM • Furniture • Answered on Apr 06, 2024
Getaway Elite Massage Chair. The wire that makes the chair move out is unplugged can't find where it plugs in?
Question edited for clarity. Back right hand side. Page 8 of the manual
RMS-10
Abt https://content.abt.com > documents > RMS10_om PDF Robotic MassageĀ® Chair ... The warranty applies only to the massage chair; accessories or enhancements are not covered. ... Get-A-Way "Elite" allows you to select ... 12 pages
4/4/2024 8:23:36 PM • Furniture • Answered on Apr 04, 2024
Where can I get a replacement door seal for my CDA Wine cooler model FWC602SS.
Check out the link. CDA sell spares direct, plus other vendors. You can also make your own. https://www.google.com/search?q=replacement+door+seal+for+my+CDA+Wine+cooler+model+FWC602SS ..
3/28/2024 5:55:14 AM • Furniture • Answered on Mar 28, 2024
Is cotton mattress good for back?
Yes it is. It is a natural material, breathes naturally and is capable of being kept clean.
3/27/2024 2:27:20 PM • Furniture • Answered on Mar 27, 2024
Kenmore 13485 Wine Cooler Logo
17 questions posted
Top Kenmore Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kenmore Furniture Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Furniture
  • Kenmore Furniture
Most Popular Question
troubleshooting kenmore wine cellar
  • Furniture
