20 Most Recent
Avermedia Smart Guard (nvdsmtgrd) Video Capture Questions & Answers
To Whom It May Concern:
We
You can try opening the avermedia software and check if the directory where the videos are saved is full. There's a chance that the place where it's trying to save the videos are full and you may have to delete some files from it.
Maybe transfer it to a USB flashdisk or an external hard drive and then try recording.
Hope this helps!
Cant find a free download
the product was dicontinued 6 years ago i think so it may be near impossible to find the drivers ... P.S. you do not need to pay for drivers, only the product itself
Avermedia Aver3d Capturehd Hey, I have problem
You must specifically run the driver and software installation as Administrator. While it may appear the automatic process did this, it really didn't.
Right-click on the installation EXE and select "Run as Administrator".
11/1/2017 10:10:49 AM •
Avermedia...
Answered
on Nov 01, 2017
Voice -yes
picture -no
if its your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or
update driver
hope this helps
2/9/2011 9:34:11 PM •
Avermedia...
Answered
on Feb 09, 2011
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
