20 Most Recent Kenmore 63672 Convection/Microwave Oven Questions & Answers
Kenmore microwave convection 721.67909 stopped working. No display either. Keys don't work. Help please Thanks Sarah Watts
Sounds like you blew a fuse. If the unit has a user-replaceable fuse, or fusible link, it will say so in the manual. There is probably a "Troubleshooting" section in the manual.
11/30/2017 4:20:58 PM • Kenmore 63672... • Answered on Nov 30, 2017
2answers
Rack in microwave
You should not have any metals in the oven when the microwave is on. If you are just doing convection cooking, the metal rack should be in so that what you are cooking is raised up so the hot air can surround what you are cooking.
8/31/2017 3:35:31 PM • Kenmore 63672... • Answered on Aug 31, 2017
Broken door latch on Model 63679 Kenmore Elite Microwave.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded views by entering your full Kenmore model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Please be aware that you may have a broken spring mounting tab on the inner door panel.
In such cases, the best way to fix that is to drill a hole in the remaining material, insert the spring, then add a dab of epoxy where they spring attaches to the panel.
7/22/2014 11:59:59 PM • Kenmore 63672... • Answered on Jul 22, 2014
Kenmore Elite micro/convect model 64289.
F 11 code. it is a touch pad error.
if you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
12/11/2013 12:15:42 AM • Kenmore 63672... • Answered on Dec 11, 2013
Kenmore 721.80400 not heating
If a turntable and it is not moving suspect a safety switch in the door, if no table or it is moving suspect possible inverter board or Magnetron itself either of which can be pricy to have replaced.
11/3/2012 7:30:03 PM • Kenmore 63672... • Answered on Nov 03, 2012
Replace a fuse for a Panasonic NN A554W
To replace a fuse, unplug microwave, remove top,"several screws" look to the right where the keypad control board is, now look down where the circuit board is, there should be a fuse clipped in, pop it out and replace with the same current rating, assemble before testing, lethal voltages.
4/10/2012 11:04:54 AM • Kenmore 63672... • Answered on Apr 10, 2012
How can i replace a schneider microwave oven light
Take the outer casing off, just remember there is one security screw from the eight you take out. once you have done that then there is a metal sheild around the bulb holder 2 further philips screws to take then just replace the bulb and re assemble, note the cover is like tongue and groove to get back on so make sure you line them up before screwing back together.
11/1/2011 9:51:31 AM • Kenmore 63672... • Answered on Nov 01, 2011
There is a plastic cover in the top of my
THe cover is covering the aerial and is possibly contaminated with something.
Replacement should fix the arcing.
2/28/2011 7:30:48 PM • Kenmore 63672... • Answered on Feb 28, 2011
I bought a used Kenmore convection oven model
This unit is no longer supported by Kenmore. There are also no spare parts available from the manufacturer.
Your best bet would be the secondary market like eBay.
THIS ONE is a close model - but not exact.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1/30/2011 10:39:31 PM • Kenmore 63672... • Answered on Jan 30, 2011
Kenmore above the range microwave doesn't heat and
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
sytjhf
9/30/2010 5:08:55 PM • Kenmore 63672... • Answered on Sep 30, 2010
Kenmore Elite 363.63679201 Display reads Demo
Press & hold POWER for 10 seconds.
9/30/2010 3:47:09 AM • Kenmore 63672... • Answered on Sep 30, 2010
MELTED SHAFT & BROKE PLATE
You will need to remove from the bottom of the oven but make sure that you hae not damaged the magnetron with the dry run.
You can try to get the part from a salvaged set as many arre available, junked when the magnetron fails.
Bothe plate and shaft can be sourced like this and will worrk outt cheaper only if you try sources of workshops.
8/26/2010 6:06:02 PM • Kenmore 63672... • Answered on Aug 26, 2010
Kenmore 63672 Convection/Microwave Oven Logo
79 questions posted
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Microwave Ovens
Most Popular Question
replace fuse panasonic nn a554w
  • Microwave Ovens
