20 Most Recent
Kenmore 61627 1000 Watts Microwave Oven Questions & Answers
Won't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
.,mbm,
Kenmore over the range microwave tripping breaker
You've found the proper location if you're seeking for the fuse for your Kenmore microwave. The fuse is often found in the microwave's or behind the control panel. You must take off the microwave's exterior cover in order to reach it.
After you've identified the fuse, you may see if it has blown. If so, you'll have to swap it out for a new one. It might be preferable to seek professional advice if you are unsure on how to proceed.
4/18/2023 8:31:03 PM •
Kenmore...
Answered
on Apr 18, 2023
When trying to use convection with Kenmore hood combination it stars then stops and the display says F-5. What does that mean
If you are getting an F-5 error code on your Kenmore hood combination, it typically indicates a problem with the temperature sensor. This error code may occur when you are trying to use the convection feature, as you have described.
To troubleshoot this issue, try the following steps:
Turn off the power to the unit and unplug it from the electrical outlet.
Wait a few minutes, then plug the unit back in and turn on the power.
Try using the convection feature again and see if the error code reappears.
If the error code persists, you may need to replace the temperature sensor. You can consult the user manual for your Kenmore hood combination or contact Kenmore customer service for assistance with this.
If the unit is still under warranty, it's recommended to contact Kenmore customer service for repair or replacement options.
4/5/2023 7:13:24 AM •
Kenmore...
Answered
on Apr 05, 2023
My Kenmore stove timer started going off every 45 seconds
It sounds like you may be experiencing an issue with your Kenmore stove's timer function. Here are a few steps you can try to resolve this issue:
Check the timer settings to make sure that the correct time and alarm settings have been entered.
Try resetting the timer by turning it off and back on again, or unplugging the stove and waiting a few minutes before plugging it back in.
Make sure that there are no buttons or knobs stuck on the stove, as this could cause the timer to activate repeatedly.
If these steps do not resolve the issue, it may be necessary to contact a professional appliance repair service for further assistance.
2/1/2023 2:26:53 AM •
Kenmore...
Answered
on Feb 01, 2023
Kenmore microwave model 401.85053010 won't heat or cook anything.
Unfortunately, this is not something that can be diagnosed from a distance, unless you had access to a "Kill-a-Watt" meter or equivalent. It could be caused by a bad door switch, a bad relay on the main board, a bad magnetron, or a bad HV diode. (The HV capacitor is probably OK, because if it were bad [shorted], it would blow fuses.)
10/28/2022 6:00:32 AM •
Kenmore...
Answered
on Oct 28, 2022
Kenmore Microwave model Fan running and light on when door closed.
This is normal. Kenmore microwaves will stay running with fan and light on for a short time after food is cooked. The reason is to air out the microwave after cooking. Things like pop corn, Bacon etc. have strong smells after cooking. The ventilation helps to remove odors.
6/3/2022 1:44:23 PM •
Kenmore...
Answered
on Jun 03, 2022
Kenmore making vibration and blowing fuse. Began repair
It is 'Magnetron'.
You shouldn't be in there Kate, there is heart stopping 120,000 volts, a poisonous heavy metal core in the magnetron and radiation that can blind you in 6 seconds. Qualified service personnel only on microwave ovens. Depending on age it is probably beyond ecomomic repair. If you have had it longer than 6 years, it is. It sounds like one of your new parts was the wrong part. If you bought them off eBay, they will be out of failed machines that have been scrapped, cleaned and resold. If you have some attraction to this oven, take it in for service. The technicians have the experience and the test equipment.
3/22/2022 4:23:02 PM •
Kenmore...
Answered
on Mar 22, 2022
