20 Most Recent
Kenmore 69682 Microwave Oven Questions & Answers
What does an F6 error code mean?
The F6 message is an error code that indicates the microwave relay has failed. This is an internal component that will require service.
My microwave makes a loud humming noise when it is turned on. What do I need to replace?
Good possibility your start capacitor is leaking. When it goes completely it will blow fuse or circuit breaker causing a dead condition. You can get and replace this yourself but be careful to discharge the capacitor with a set of test leads across the terminals. This part can hold dangerous voltage! Of course, unplug the unit first. The magnetron is expensive if you can even get one. For the cost of most new units, this may be too much unless it’s a over the stove model.
Error code
F6 is a communication error. It is either a loose connection to the control board, or the control board is shot. They should have diagnosed this when they came out to fix it. Open it up, and look for loose connections.
good luck
Kenmore over the range microwave tripping breaker
You've found the proper location if you're seeking for the fuse for your Kenmore microwave. The fuse is often found in the microwave's or behind the control panel. You must take off the microwave's exterior cover in order to reach it.
After you've identified the fuse, you may see if it has blown. If so, you'll have to swap it out for a new one. It might be preferable to seek professional advice if you are unsure on how to proceed.
4/18/2023 8:31:03 PM •
Kenmore...
Answered
on Apr 18, 2023
When trying to use convection with Kenmore hood combination it stars then stops and the display says F-5. What does that mean
If you are getting an F-5 error code on your Kenmore hood combination, it typically indicates a problem with the temperature sensor. This error code may occur when you are trying to use the convection feature, as you have described.
To troubleshoot this issue, try the following steps:
Turn off the power to the unit and unplug it from the electrical outlet.
Wait a few minutes, then plug the unit back in and turn on the power.
Try using the convection feature again and see if the error code reappears.
If the error code persists, you may need to replace the temperature sensor. You can consult the user manual for your Kenmore hood combination or contact Kenmore customer service for assistance with this.
If the unit is still under warranty, it's recommended to contact Kenmore customer service for repair or replacement options.
4/5/2023 7:13:24 AM •
Kenmore...
Answered
on Apr 05, 2023
My Kenmore stove timer started going off every 45 seconds
It sounds like you may be experiencing an issue with your Kenmore stove's timer function. Here are a few steps you can try to resolve this issue:
Check the timer settings to make sure that the correct time and alarm settings have been entered.
Try resetting the timer by turning it off and back on again, or unplugging the stove and waiting a few minutes before plugging it back in.
Make sure that there are no buttons or knobs stuck on the stove, as this could cause the timer to activate repeatedly.
If these steps do not resolve the issue, it may be necessary to contact a professional appliance repair service for further assistance.
2/1/2023 2:26:53 AM •
Kenmore...
Answered
on Feb 01, 2023
Kenmore microwave model 401.85053010 won't heat or cook anything.
Unfortunately, this is not something that can be diagnosed from a distance, unless you had access to a "Kill-a-Watt" meter or equivalent. It could be caused by a bad door switch, a bad relay on the main board, a bad magnetron, or a bad HV diode. (The HV capacitor is probably OK, because if it were bad [shorted], it would blow fuses.)
10/28/2022 6:00:32 AM •
Kenmore...
Answered
on Oct 28, 2022
Kenmore Microwave model Fan running and light on when door closed.
This is normal. Kenmore microwaves will stay running with fan and light on for a short time after food is cooked. The reason is to air out the microwave after cooking. Things like pop corn, Bacon etc. have strong smells after cooking. The ventilation helps to remove odors.
6/3/2022 1:44:23 PM •
Kenmore...
Answered
on Jun 03, 2022
