20 Most Recent
Saeco Vienna Espresso Machine Questions & Answers
Saeco Primea Ring stuck on warming up
HiI had the same problem and could solve it but i had take the machine apart.Under boiler you have 2 thermo fuses that can be resetted. After reset i have checked if boiler get 220volt, It did for a short while but the fuses goes off again.That means boiler is ok, it gets hot but fuses goes of due to temperature reach over 170 degrees celcius. That means that the power is olways on to the heater and doesnt stop to heat.In diagnostic i could see that the temperature sensor does show the high temperature. That means that temp. sensor is ok which leads to the controller of the power to boiler. On the board i found big heatsink and a triac atached to it. I soldered it out and measure that it was spoiled.Ordered new one for 3 euro. Soldered new one on the board and the problem was solved.Original was BTA16-700CW but they didnt have it so i replaced it with BTA16-600CW, difference is that original one can handle 700volt the new one 600, but there is only 220volt it will controll anyway so that was ok.I atach a picture.Regards, Pawel
Saeco Vienna - I turned on the coffee machine and
Hi
Its hard to say with what you have said, but if the brew unit was cycling slowly, it may be the board. Close the door and make sure that everything is in but the brew unit. Turn the machine on and see if it cycles the gear in back to the starting point. It may take a few minutes to cycle if its the board. If it returns its the board. I have some boards.
Saeco Vienna superautomatica leaks when making coffee
This is an easy fix for a 14$. The seal at the water tank connection is worn. Take the water tank off. There is a round flat topped plastic retainer. Pry off the retainer (comes off easily). You will see a black round o-ring made to fit on a channel. Remove the o-ring and replace.Two minutes and you are without water leaks. I do not remove the tank to fill anymore, I use a pitcher instead. Part number 3 in this diagram.http://www.partsguru.com/user/VIENNA%20PLUS%20DIAGRAM.pdf
Why my saeco vienna plus coffee machine does not turn on
A little more info would be helpful. When you say" turn on" do you mean there is no power or do you mean the machine will not cycle when the brew button is pushed? Also, is the red light on if there is power? If there is no A.C. power that would mean the fusible link or
thermistor has opened. Do of course make sure there is power at the outlet, even experts get fooled by panel breakers being tripped ha!
Why does it lak at the bottom
it might be the 2 rubber o'rings that are fit on the injection pipe that need to be replaced.
This part inject the hot water inside the brew group.
If you remove the group, you will be able to see it, with its two o'rings (generally orange color). Try to replace them both.
Hope that helps.
