20 Most Recent Delta Faucet Delta T4738-PT Lahara Two Handle Roman Tub Trim with Hand Shower - with Lev Questions & Answers
How do install delta shower
If you are looking to replace only the shower head, you'll need two plumber's wrenches, a cloth, and Teflon tape. First and foremost, read the install instructions that come with the new shower head... After you clearly understand what the instruction's say, shut of the water supply lines for the hot & cold water. Take one of the wrenches and apply it to the neck of the water supply tube coming out of the shower wall (a.k.a. goose neck or supply nipple, or arm, depending upon the design). It'll have male threads (the threads are on the outside of the fitting). I would place a cloth of some sort around it before placing the wrench on it so you don't mar the finish of the water supply tube. Place the second wrench on the shower head assembly (which has the internal, female threads). and unscrew it by turning the shower head assembly counter-clock-wise (to the left) while holding the water supply nipple with the other wrench. You need to do this, so you don't snap or deform the water supply nipple coming out of the shower wall- and/or possibly causing leaky damage to the fittings behind the shower wall. To replace the shower head, you reverse the removal process- the only difference is, you wrap Teflon tape around the male threads of the water supply nipple before spinning on the new shower head. Somethings to be careful of, and I can't stress this enough, DO NOT cross thread the new shower head onto the water supply nipple. You should be able to screw it on the new shower head by hand- where it is hand tightened- then using the double-wrench method that you used to take off the shower head, turn the new shower head an additional half to three quarter turns with the wrench, clock-wise; and I mean gently. Here's a nice short video on the subject, illustrating my instructions: http://youtu.be/fiv4Zq9v4co
7/29/2014 1:34:01 AM • Delta Faucet... • Answered on Jul 29, 2014
0answers
DELTA SK 2898
Be the first to answer 5/18/2012 4:07:02 AM • Delta Faucet... • Posted on May 18, 2012Be the first to answer
I am looking for a
Think I can direct to the installation manual you are looking for......
www.faucet-warehouse.com/Delta/lahara/two-handle-centerset/oil-rubbed-bronze/2538lf-rb
9/6/2011 12:09:16 AM • Delta Faucet... • Answered on Sep 06, 2011
Have installed a Delta 142910-ss
If it's an old Delta, then there's a set screw on the valve behind the plate. If it's the newer version, then there is a notched plastic piece behind the handle.
3/7/2011 4:04:53 AM • Delta Faucet... • Answered on Mar 07, 2011
Ao ligar meu aparelho nokia ele desliga sozinho
The SIM may be disabled or the phone's IMEI is blocked.
Ou SIM pode ser disligado. Ou telefone pode ser bloqueado para a compania cellular. Liga par a seu compania e pergunta a eles..
3/5/2011 9:50:08 AM • Delta Faucet... • Answered on Mar 05, 2011
Ok i have a delta faucet with the cartridge one
You should check with delta I know where i but my plumbing supplies a lot of the delta brands have lifetime replacement parts on them so ask your lumberyard where you purchased it Delta may send you replacement parts for free. Good luck.
1/5/2011 6:25:57 AM • Delta Faucet... • Answered on Jan 05, 2011
Leaks
replace rubber seat cups and springs. replace stem and ball with brass parts if available.they last longer than the nylon ones. lubricate moving parts with valve stem grease. do not over tighten when re-assembling
9/16/2010 8:14:11 PM • Delta Faucet... • Answered on Sep 16, 2010
We have two new faucets
if the water pressure is high all thru the house then turn down the valve on water main or or if well adjust cut in -cut out or valve down a bit if just high at tubs can adjust valves on water line can install a water saver behind shower head or if u have access to the valve body in wall there are adjustments on both sides where the water lines come into -----if this is about temp in ur paperwork advises how to adjust the anti-scold --remove handle and trim will see a blue and red plastic clip on valve stem adjust till temp is comfortable
8/22/2010 3:30:36 PM • Delta Faucet... • Answered on Aug 22, 2010
Leaky(slow Drip) from 1700 series
you need to shut off the main water supply
take it apart an put new seals in it where bought it should have the rebuild parts
8/19/2010 2:19:17 AM • Delta Faucet... • Answered on Aug 19, 2010
2answers
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM • Home • Answered 2 days ago
3answers
Atomic Wallet Support Number
However, Atomic wallet is available in desktop and mobile versions which provides convenience. And it is a decentralized wallet where you will get private key for every coin you store in it. It is an open source wallet which means no one can infuse any malicious code into it. https://steemit.com/atomic/@abhijeetcg/atomic-wallet-comparison-with-other-existing-crypto-wallets
4/12/2024 11:27:48 AM • Home • Answered on Apr 12, 2024
3answers
What are the different types of fire extinguishers?
there are 3 types:watercarbon dioxidedry chemicalto learn more about them go here: http://www.ehs.okstate.edu/modules/exting/Types.htm
4/10/2024 10:24:39 AM • Home • Answered on Apr 10, 2024
Delta Faucet Delta T4738-PT Lahara Two Handle Roman Tub Trim with Hand Shower - with Lev Logo
2 questions posted
Top Delta Faucet Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Delta Faucet Home Expert? Answer questions, earn points and help others
View Most Popular
Delta Faucet Home
  • Delta Faucet Home
Most Popular Question
delta lahara tub faucet once hot water
  • Home
