20 Most Recent
Pioneer FH-X700BT Questions & Answers
How to remove paired devices on pioneer fh x700bt
Push and hold the phone button until you get a display, now using the big round button in the middle turn to your right until you get to the Bluetooth set up it will say program or delete and you delete the the paired device, and that takes it back to the factory reset.
5/18/2019 10:33:20 PM •
Pioneer...
Answered
on May 18, 2019
Trying to install the fh-x700bt into my 2005 gmc envoy. I am using the GM1590AB and the GM05B + Red Wire. I was able to connect all of the speaker wires correctly. I'm having trouble beyond that. The
The amplifier is in the passenger side rear quarter panel.
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
9/30/2014 5:13:56 PM •
Pioneer...
Answered
on Sep 30, 2014
2001 VW pASSAT MONSOON SYSTEM BATTERY IS DRAINING?
In our car, the power wire is connected to a source that is only hot when the Key is in the ignition and turned to the Acc or On position. We have had no issues with the stereo draining the battery.
6/4/2014 11:58:45 PM •
Pioneer...
Answered
on Jun 04, 2014
