20 Most Recent KitchenAid 32 in. KECC502 Electric Cooktop Questions & Answers
I wish I had the exact answer, because I have the same exact problem!!! You posted this about a month ago, which is when my unit started having LED "on" problems. Just in the past week, the top left power on LED will not go off, and nothing I can do gets the dual large burner to come on. Any thoughts??? Reply to: [email protected]
KitchenAid 32... | Answered on May 02, 2010
I have this same trouble with the same brand and model number of cooktop. Have you found a solution?
KitchenAid 32... | Answered on Dec 07, 2009
it's called a rheostat -no it is not hard to replace ---open the breaker, of course. write down the wiring if you think necessary---then remove and replace. you might want to check/compare the rheostat to one of the others to verify it as the problem
KitchenAid 32... | Answered on Jun 26, 2009
Sounds like that specific element has shorted to ground inside it's sheath. You'll probably find the element does not get as hot as it normally would.
A fuse will not blow, or breaker not throw, because of the point in the element that the element has grounded.
Elements are available from a number of resources.
A way to test if the element is shorted to ground:
Tools needed -
Ohmeter
1)Disconnect power from the appliance
2) Remove the element (Sometimes they are plugged in, sometimes the wires screw onto the ends of the element.
3) Set the Ohmeter to Rx1000 or more.
4) Measure the resistance between the outside metal sheath, and either of the two power connection points on either end of the element. Under any condition, you should not get a reading. If you do, the element is bad, and you need to get a new one. They are not repairable.
5) Re-install in the reverse removed.
6) Check all connections are clean and all is re-assembled as you originally found it.
7) Turn on power and check if element comes on.
It is unlikely the problem is with the control, but it is a possibility. Give me more info about the cook-top (make, model) so I can investigate further.
KitchenAid 32... | Answered on Jan 14, 2009
Held all off/on button for 5 seconds cleared the problem,
KitchenAid 32... | Answered on Dec 25, 2008
Needs to be serviced. The electronics for the igniter section has gone bad.
KitchenAid 32... | Answered on Sep 03, 2008
Almost certainly the switch, not the element, Had the same problem on a different stove - went to 10 no matter what the knob was set to.
Here is a parts list, you should be able to get the part from a local appliance part seller. I used ReliableParts in my town.
https://www.partselect.com/ModelSections.aspx?ModelID=815598&ModelNum=KECD805HBL3&mfgModelNum=&ManufactureID=3&Selected=ZPGZLZRB&Position=2&mfg=Whirlpool&Type=Cooktop&Mark=2
KitchenAid... | Answered on Oct 31, 2019
Contact KitchenAid directly and ask what the cutout size is for cooktop kecc508. They may be able to supply a template.
KitchenAid... | Answered on Nov 20, 2018
You need one with a smooth stainless steel or aluminium bottom. Don't use cast iron because it is rough. Or you could sit any on a round profile metal triangle. Here is a star shaped one
2 Pack Stove Ring Heat Diffuser Metal For Electric Gas Glass Stove Top...
KitchenAid... | Answered on Oct 02, 2017
KitchenAid 32 in. KECC502 Electric Cooktop Logo
20 questions posted
Top KitchenAid Cooktops Experts
Marvin
Marvin
ray gallant
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Cooktops
  • KitchenAid Cooktops
Most Popular Question
kitchenaid kecc502 cooktop dual burners
  • Cooktops
