20 Most Recent KitchenAid 36 in. KECC568 Electric Cooktop Questions & Answers
0answers
0answers
tip
Fault Codes Kitchen Aid cooktop
F03 One or more eyes permanently pressed. Recommend that the glas be cleaned and all objects removed.<br /> Unplug the unit for one minute the plug back in if the error still remains after returning power then you will need to replace the touch control module.<br /> <br /> F12 Electronic board and touch module communication error.Unplug the unit for a couple of minutes.Restore the power if the error return then you will need to replace the board connection cable between the touch control module and electronic control. if the error remains replac ethe electronic control board. If the error comes back again replace the the touch pad.<br /> <br /> F13 Internal CPU checksum error.Recommend you replace the touch control module.<br /> <br /> F22 Key sensitivity problem.Turn power off to unit for a few minutes,if the error returns after power is restored replace the touch control module<br /> <br /> F36 Temperature probe hardware error.Recommend that you replace the touch control module.
I need tio hook up a 4 wire cooktop(Bl R, W,
hi my name is mark, you need to check local electrical code before wiring cooktop. if it is allowed the white and ground/copper can be tied together with green from house. but if not allowed you will have to run a seperate white wire or new 8ga 3 wire/ with ground from breaker box. check the code first. and shut off power before you wire cooktop. thanks for your question.
3/15/2009 12:48:19 PM • KitchenAid 36... • Answered on Mar 15, 2009
My Kitchen aid cooktop model number KECC667BBL won't turn on
Mis-wired or the new control panel is faulty. Call them back, it is under repair warranty. The parts aren't cheap! https://www.searspartsdirect.com/model/41v4g0ja62-000593/kitchenaid-kecc667bbl01-electric-cooktop-parts ..
2/9/2022 7:12:27 PM • KitchenAid... • Answered on Feb 09, 2022
2answers
My intermittent ignition device on kitchen aid stove is not clicking.
igniter failed
2/1/2022 2:58:28 PM • KitchenAid... • Answered on Feb 01, 2022
Kitchenaid Electric cooktop KECCD805HBL3 Left front 8" eye only cycles at high heat no matter what the setting. Do I need a new eye or switch or both?
Almost certainly the switch, not the element, Had the same problem on a different stove - went to 10 no matter what the knob was set to. Here is a parts list, you should be able to get the part from a local appliance part seller. I used ReliableParts in my town. https://www.partselect.com/ModelSections.aspx?ModelID=815598&ModelNum=KECD805HBL3&mfgModelNum=&ManufactureID=3&Selected=ZPGZLZRB&Position=2&mfg=Whirlpool&Type=Cooktop&Mark=2
10/31/2019 9:34:41 PM • KitchenAid... • Answered on Oct 31, 2019
I'm installing a kitchen aid cooktop. How do you attatch brackets on cooktop installation?
They go under the counter and they are screwed in place
2/7/2017 12:14:50 AM • KitchenAid... • Answered on Feb 07, 2017
After we had a tech to fix the glass top and one burner, the f1:e1 code came out and kept beeping. I was told it could be the control board problem. Could it be loosen wiring problem too?
Hi, Need model number of your range to answer this question. Is this gas or electric? Is this a freestanding range or cooktop because I only can find information on ranges with this fault code given. All should EEPROM communication error which is a communication error on start up. when the top was damaged was the unit being used? Was water or liquid a factor when this damage happened? A loose wire would be a different error code or fault code like a F2 - E1 or E2, not your code given. I hope this helps, need more information. Thanks I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
4/19/2016 12:17:22 PM • KitchenAid... • Answered on Apr 19, 2016
After we had a tech replacing a new glass cooktop and one burner, the f1:e1 came out and kept beeping. could it be loosen wire or the problem of the control board?
Call the repair company to come back. It's possible he didn't hook something up right. ...
4/17/2016 6:02:40 PM • KitchenAid... • Answered on Apr 17, 2016
This is not the oven it is the cook top. After it was accidently turned all off and locked I can not get it to turn back on.
To Unlock Cooktop: Touch and hold the CONTROL LOCK/ ALL OFF keypad for 5 seconds.
12/6/2015 11:04:12 PM • KitchenAid... • Answered on Dec 06, 2015
Change ignition control module
changing everything on this kitchenaid cooktop video
6/27/2015 11:33:48 PM • KitchenAid... • Answered on Jun 27, 2015
KitchenAid 36 in. KECC568 Electric Cooktop Logo
12 questions posted
Top KitchenAid Cooktops Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Cooktops
  • KitchenAid Cooktops
Most Popular Question
need tio hook up 4 wire cooktop bl r w
  • Cooktops
