20 Most Recent Danco Faucet Stem Questions & Answers
It sounds like you might be missing a part. Check your list for all included parts. All parts are critical.
Danco Faucet... | Answered on Sep 04, 2017
  • Shut off water supply
  • Open faucet
  • Remove knob
  • Unscrew old stem
  • Use flashlight to inspect seat for damage and corrosion. Dress or replace seat if necessary.
  • Install new stem
  • Reinstall knob
  • Turn on water supply and check for leaks
Danco Faucet... | Answered on Jun 20, 2016
If your having major issues, I would try to locate the main on/off valves at your water heater and pump/cold water line in the basement. One the water is shut off, I would try to check if there is a proper seal...as required concerning the stem. It's probably on of the old gaskets that was not remove and doubled up. Happened to me. Good luck!
www.youtube.com/watch?v=kM-TxozD-b4
Danco Faucet... | Answered on Mar 01, 2015
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Danco Faucet... | Answered on Aug 11, 2014
Change the O rings in the mixer.
Danco Faucet... | Answered on Mar 17, 2014
The same part works for both Hot & Cold sides. Usually preset to work on Hot (counter clockwise on, clockwise off). To set for Cold, simple remove the plastic clip from the top, slide the ring tab off, flip it over and put back on (you can only put it on one way since there's a flat "key" in it matching the stem) Now its set for Cold (CCW of, CW on). HTH
Danco Faucet... | Answered on Dec 25, 2013
One of two things has happened. I'm assuming you only get hot water when you open the valve and that this is for a single handle control shower fixture. If so either this is the wrong valve for your shower control or it is installed backwards. Sometimes the valve can be installed at either 180 degree angles. See if it can be installed any other way. If so this may solve the problem.
Danco Faucet... | Answered on Nov 16, 2013
Danco Faucet Stem  Logo
Popular Tags
65 questions posted
Top Danco Home Experts
Bill Johnson
mehan
Level 1 Expert
Tom Chichester
Are you a Danco Home Expert? Answer questions, earn points and help others
View Most Popular
Danco Home
  • Danco Home
Most Popular Question
assemble install danco 9s 4h c
  • Home
