20 Most Recent Danco Clear Faucet Decorator Handles Questions & Answers
Get some Lock-tight formula to apply to the screw. Let it dry a few minutes after application. Naturally, after application of the solution, you have tightened the screw to its maximum. Do not be concerned about ever removing the screw as the material will loosens when you apply manual force.
Danco Clear... | Answered on Feb 07, 2018
Have you checked with a plumbing supply hose if it is a square slot you may could use a handle off a boiler drain for a washing machine .
Check it out if it is a metal red or blue metal it may be the same type used on your washing machine cut off valve
Danco Clear... | Answered on May 05, 2010
Each manufacturer has a different size shower spout. As long as the fitting doesn't leak, put a flange up against the wall and if needed, use calking to fill the space. This is an aesthetic issue only.
Danco Home | Answered on Oct 01, 2019
Is this a question?
Danco Home | Answered on May 23, 2019
Most of those have a quarter turn plastic pie section at the top of the stem. It reverses for right or left (cold or hot) faucets. Turn off the water supplies, remove the top of the faucet and handles, put the pie shaped sections on opposite sides, reinstall the handles and turn the water supplies back on.
Danco Home | Answered on May 14, 2019
By replacing it
Danco Home | Answered on Jul 08, 2018
The issue might be the tub diverter spout. Most such do not seal well. It is a matter of jiggling the spout knob. It should seal better with a little experimenting.
Danco Home | Answered on Sep 04, 2017
Umm, yeah I think so....
Danco Home | Answered on Nov 10, 2013
Step 1. First things first, load test the battery. Most places like Auto Zone will do it for free. Even if it measures over 12.5 vdc it can still be bad under a load. Battery is typically rated at 19 amp hours and 270 Cold Cranking Amps (CCA).
Start the engine and measure DC Volts across the battery terminals, the regulator should be putting out 14.3 - 14.7 vdc at 3600 rpm and 75 degrees F.
Step 2. To check the regulator unplug it from the stator. Take a test light and clip it to the negative terminal of the battery and then touch first one pin and then the other on the plug that goes to the regulator. If you get even the slightest amount of light from the test light the regulator is toast.
To do this with a meter which is more accurate: black lead to battery ground, red lead to each pin on the plug, start with the voltage scale higher than 12vdc and move voltage scale down in steps for each pin. Any voltage is a bad regulator.
Step 3. On the other part of the disconnected regulator plug. Set the multimeter for Ohms x1 scale and measure for resistance across the pins of the stator. You should read something around 0.1 to 0.2 ohms for the TC88 32 amp system.
Step 4. Then check for continuity between each pin on the plug and frame/engine ground. The meter needle should not move (infinite resistance)(digitals will show infinite resistance) if the meter needle does move (indicating continuity)(digitals will show some resistance), recheck very carefully. If the meter still shows continuity to ground the stator is shorted (bad).
Step 5. Set the meter to read A/C volts higher than 30 volts (the scale setting for voltage should always be higher than the highest voltage you expect or you may fry the meter). Start the bike, and measure from one pin to the other on the plug (DO NOT cross the multimeter probes! - touch them to each other). You should read roughly 16-20 vac per 1,000 rpm.
Step 6. If the battery was good under load test, if the stator is NOT shorted to ground, and the stator is putting out A/C voltage, then the regulator is bad (most likely even if if passed step 2).
Danco Home | Answered on Jul 24, 2011
Danco Clear Faucet Decorator Handles  Logo
2 questions posted
Top Danco Home Experts
Bill Johnson
Tom Chichester
Are you a Danco Home Expert? Answer questions, earn points and help others
View Most Popular
Danco Home
  • Danco Home
Most Popular Question
danco universal faucet replacement
  • Home
