20 Most Recent Water Pik Shower Head Questions & Answers
There can be various reason of water drizzle, the main reasons are:
1. Low water pressure, it's the main reason for water drizzling. Check the water pressure of your house and if it's loo low then fix it.
2. Rust in your shower head, if your shower heads is full of rust it can be a reason for water drizzling. Clean your shower head nicely to remove those.
Thanks.
Water Pik Shower... | Answered on Oct 15, 2018
There should bea rubber gasket/washer that goes between threads on shower arm and inside of shower head. If this is a new shower head I would return it to place of purchace for exchange. If not you should be able to get the waher seperatly. If not you can get a cheap shower head and use the gasket from it. I also would recommend that you use several wraps of teflon pipe joint tape on shower arm and tighten snugly.I hop this helps you. Thank you a have a good year
Water Pik Shower... | Answered on Jan 07, 2013
That model is an integrated swivel trs 553. Take the swivel head holder off the pipe and check the o rings and nylon washers if the bracket is flopping around on the head of the pipe. I believe the nylon washer and oring need replaced. You can get those at any hardware store.
Water Pik Shower... | Answered on Jan 16, 2011
I understand that the white vac breaker end should be connected to the valve not the hand shower. FYI a little leak from this connection when the water is switched off is normal.
Water Pik Shower... | Answered on Sep 30, 2010
Just rotate the head in anti clockwise
Water Pik Shower... | Answered on Aug 27, 2010
You need your old shower head and the new one, go to the hardware store and tell them you need a pipe adapter with a female side that fits the old one and a male side that fits the new one. They'll be able to pick it out for you.
What you're looking for is commonly called a pipe adapter or "nipple".
Water Pik Shower... | Answered on Aug 09, 2010
how old is the shower?
Its a mixer, am I correct?
Water Pik Shower... | Answered on May 07, 2010
If your unit has a threaded connection for the handle and hose the threads are most likely stripped. You can get thread grip material at most hardware stores and repair it yourself. Otherwise replacement is necessary.
Water Pik Shower... | Answered on Feb 21, 2010
Loose washer in hot or cold tap. Replace or tighten.
Water Pik Shower... | Answered on Sep 13, 2009
You just need to figure out which one you have and the manual should be on this site. If its not then give them a call.
http://www.waterpik.com/customer-service/instruction-manuals.html
Water Pik Shower... | Answered on Apr 03, 2009
Physicly cleanit or bleach/vinegar
Water Pik Home | Answered on Oct 25, 2018
Water Pik Shower Head  Logo
23 questions posted
Top Water Pik Home Experts
Marvin
Marvin
john h
Are you a Water Pik Home Expert? Answer questions, earn points and help others
View Most Popular
Water Pik Home
  • Water Pik Home
Most Popular Question
gainsborough royale antique not get cold
  • Home
