20 Most Recent KitchenAid KEMC378KSS Electric Double Oven Questions & Answers
4answers
Problem with the KitchenAid KEMC378
FixYourBoard.com will test and remanufacture the oven control board in this model. We also have touchpads ( aka keypad membranes ) available for this model. Each rebuild comes with a two year warranty. Reach out to us at 512-355-1108 or [email protected] ledgestone kp2b1705-undefined-undefined-0.jpg
3/24/2020 3:39:02 PM • KitchenAid... • Answered on Mar 24, 2020
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. Theywill come on when the oven door is opened. On double ovenmodels, both upper and lower lights will come on when eitherdoor is opened. The oven lights will not work during the Self-Cleaning cycle. When the oven door is closed, press OVENLIGHT to turn them on or off.To Replace:Before replacing, make sure the oven is off and cool.1. Disconnect power.2. Remove glass light cover by grasping the front edge andpulling away from oven2_4_2013_9_12_23_pm.png3. Remove bulb from socket.4. Replace bulb, replace bulb cover by snapping back into wall.5. Reconnect power.
2/4/2013 9:13:45 PM • KitchenAid... • Answered on Feb 04, 2013
Display on microwave reads door
switch for the door is not engaging so as to shutoff this message.
9/11/2012 5:46:58 AM • KitchenAid... • Answered on Sep 11, 2012
How do i change the magnetron?
I suggest check the next video about How to change your magnetron tube in your GE Microwave...
Hope helps.
5/14/2011 12:44:19 PM • KitchenAid... • Answered on May 14, 2011
Can you explain how to replace the light bulb in
This worked like a charm ... actually it's easier than you might think. Just a few screws and a few tugs. Give it a shot.. I found a 10W (G4 style ... you'll see the difference when you get to the store) replacement bulb at Home Depot for $6:
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with your fingers or pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
3/7/2011 5:48:22 AM • KitchenAid... • Answered on Mar 07, 2011
2answers
How do i change light bulb for my oven
Here is a simpler method from the same website mentioned in solution #1:
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
By the way, the bulb is Osram 64405S. It's available online for about $2.00 plus shipping.
See more info. at: http://www.howtomendit.com/answers.php?id=51232
2/18/2011 12:41:45 AM • KitchenAid... • Answered on Feb 18, 2011
Microwave has power...light lights and turn table
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
11/19/2010 3:16:34 AM • KitchenAid... • Answered on Nov 19, 2010
2answers
KitchenAid KERI203PBS Oven. I set to 400, it only gets to about 325.
Question edited for clarity, the MAKER, and 'what is is'. Question moved to KitchenAid. You may have a bad sensor. Not sure Amazon is the best place to buy. A lot of parts are no longer available, so you should perhaps be thinking of a replacement? https://www.partselect.com/Models/KERA205PSS5/Sections/CHASSIS-PARTS/?ModelID=679473&ModelNum=KERA205PSS5&mfgModelNum=&ManufactureID=3&Selected=N7FWPBQ3&Position=1&mfg=Whirlpool&Type=Range&Mark=1 Is the fan spinning okay? This suggests a bad fan. It has a small circular element around the fan. https://www.google.com/search?q=kitchenaid+keri203pbs+oven+not+reaching+temperature ..
8/28/2022 9:50:28 AM • KitchenAid Ovens • Answered on Aug 28, 2022
Kitchenaid architect 2 series model# kgr58075550 dead need locations of fuses and board to check
sounds like overheated bad control board or transformer
8/28/2022 9:48:57 AM • KitchenAid Ovens • Answered on Aug 28, 2022
Why is my KEBC107KSS oven Close Door Light intermittently On when my door latch is working perfectly fine?
WE HAVE NO INFORMATION AND SEBSTITUTE PARTS SORRY
1/2/2022 11:09:42 PM • KitchenAid Ovens • Answered on Jan 02, 2022
KitchenAid KEMC378KSS Electric Double Oven Logo
20 questions posted
Top KitchenAid Ovens Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Ovens
  • KitchenAid Ovens
Most Popular Question
change light bulb oven
  • Ovens
