20 Most Recent KitchenAid KEBC278 Electric Double Oven Questions & Answers
Hi chuck1122
Thanks for your question at Fixya,
Please find the solution to your problem as follows :-
The problem is with a faulty circuit board which needs to be replaced or repaired by Kitcehaid.
If you have this product under warranty then you need to get it repaired / replaced for free , or else pay for the repair or replacement , by first considering the cost factor involved in it.
Hope this helps ...:) In case you have any queries , feel free to contact me.
KitchenAid... | Answered on Sep 25, 2011
the oven needs to reheat to self clean. / try to run a new clean cycle and it should re open and end . mm
KitchenAid... | Answered on Jul 15, 2010
wshort, As long as you are sure the circuit to the oven is not the problem,such as drop in voltage, here are a couple of suggestions. Number one is that the electronic parts for this model have a five year warranty on them and you may want to call for factory service. Sometimes the connections on the main control board become loose or corroded. Try reseating them and see if the problem stops. If not I would suspect the control board power transformer behind the control board. There are two transformers, one for lights the other for the control board. The control board transformer should have the red and blue wires while the light transformer will have the black and white. The voltage could be dropping out here. Make sure that the wires to the oven terminal block are not loose or burnt. Since you are not receiving any error codes except for PF, Im not suspecting the board itself. Catriver...post back.
KitchenAid... | Answered on Dec 26, 2006
Request the Superba model kebc107kss03 manual directly from KitchenAid.
KitchenAid Ovens | Answered on Oct 29, 2020
Is it possible you've blown a breaker? Probably a double-breaker, 220V.
KitchenAid Ovens | Answered on Oct 27, 2020
the latch the hooks into the door is caught inside the slot where it locks into when in self clean,you have to move the latch,unplug it,look through the air vents or slots up above the door if you can get a screw driver in there try to move the latch or if you can get something down inside to move the latch,i used a plastic long wire tie to do this before,i slid the tie down around the metal hook part of the latch that locks into the door,and pulled it to the left and got the door to open,it got hung up in the hole and the door wouldn't open but what ever works you have to move the hook part of the latch to get the door open,you can try picking up on the door to see if you can get it open or you'll have to pull the oven out and take the top off to get at the latch,hope this helps
KitchenAid Ovens | Answered on Jul 04, 2020
In our case, the error code was displayed on a KitchenAid microwave/oven combo. It turned out to be a $4 fuse called the "Main Cavity Fuse". Good luck.
KitchenAid Ovens | Answered on Mar 04, 2020
Hi, my name is Audrey. I am a KitchenAid employee and would appreciate the opportunity to assist you with your oven. Please send me an email through our customer service address,
[email protected] and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model and serial number, and I would be happy to try to help resolve the situation with your appliance.
KitchenAid Ovens | Answered on Aug 07, 2019
Hello Susan Bailey,
Typically "THEY" do...
It would be really great to know if we are talking about a USA domestic product...
or another NATIONALITY.
Other countries normally have FUSES in the
appliance cords.
Find your MODEL NUMBER and go to a PART/SPARES
supplier ( I like appliancepartspros.com )
-> appliancepartspros.com
If this is a "MICROWAVE" the FUSE will start popping because the MAGNETRON has deteriorated
and is CONSUMING it's own energy.
I can be a LOT MORE specific if you provide a
model number (pretty please).
Read minds... Cannot rally do...!!
https://en.wikipedia.org/wiki/Carnac_the_Magnificent
KitchenAid Ovens | Answered on Jun 25, 2019
Possible Solutions
Reset power to the product:
There may be a problem with the Oven Appliance Manger Control or the associated wiring.
  • Power unit down by turning off the circuit breaker(s) for one (1) minute.
  • Power unit up by turning on the circuit breaker(s).
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify oven operation.
Still need help? Call or schedule service.
KitchenAid Ovens | Answered on Feb 02, 2019
the is an external fan which draws all the moisture away,pull oven out and follows the two wires frm the and make sure both are connected and connected so it is alive when oven is on, if good the probaly a faulty fan
KitchenAid Ovens | Answered on Jul 15, 2018
KitchenAid KODE507ESS
(this MAY be your model??)... you did not specify?...
This link MAY have your DISPLAY PARTS:
KitchenAid Range Stove Oven Display Board
Anthony
KitchenAid Ovens | Answered on Jul 09, 2018
From the Site:
"F2-E6 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly. All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD)."
Kitchen Aid Appliance Fault Codes
Hope this helps!
Anthony
KitchenAid KEBC278 Electric Double Oven Logo
7 questions posted
Top KitchenAid Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
jdthefixer
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Ovens
  • KitchenAid Ovens
Most Popular Question
go pf when none
  • Ovens
