20 Most Recent KitchenAid Architect Series KEBC177KSS Electric Single Oven Questions & Answers
I have a Kitchen Aid
This happened to me three times with a brand new oven, they kept coming back and replacing the fuse. I finally made the Kitchenaid dealer replace the whole oven, never happened again.
10/4/2019 11:43:17 PM • KitchenAid... • Answered on Oct 04, 2019
0answers
Kitchen Aid Oven Superbra was used for self
Sometimes self cleaning blows a fuse, had ours changed five times and then they finally replaced the oven altogether.
11/24/2013 6:33:34 PM • KitchenAid... • Answered on Nov 24, 2013
I cleaned over with self clean and it blows the
if u have unproper vent specs on unit it will blow. read instellation spect for proper vent specs
2/12/2010 8:45:17 PM • KitchenAid... • Answered on Feb 12, 2010
Kitchenaid KGRS807SSS00 oven gas valve shutting off after successful ignition
Do you have a flame sensor ? As it sounds like the flame sensor is not clean . Or its cracked and not sending a signal back to the spark module . I would also check the connetions are clean and tight .
9/12/2021 7:13:32 PM • KitchenAid Ovens • Answered on Sep 12, 2021
Kitchenaid superba owners manual kebc107kss03
Request the Superba model kebc107kss03 manual directly from KitchenAid.
10/29/2020 3:38:47 PM • KitchenAid Ovens • Answered on Oct 29, 2020
I have a KitchenAid Superba double wall oven Model KEBS207DBL1. None of the four oven lights will come on.
Is it possible you've blown a breaker? Probably a double-breaker, 220V.
10/27/2020 11:54:26 AM • KitchenAid Ovens • Answered on Oct 27, 2020
2answers
KitchenAid Superba oven will not
the latch the hooks into the door is caught inside the slot where it locks into when in self clean,you have to move the latch,unplug it,look through the air vents or slots up above the door if you can get a screw driver in there try to move the latch or if you can get something down inside to move the latch,i used a plastic long wire tie to do this before,i slid the tie down around the metal hook part of the latch that locks into the door,and pulled it to the left and got the door to open,it got hung up in the hole and the door wouldn't open but what ever works you have to move the hook part of the latch to get the door open,you can try picking up on the door to see if you can get it open or you'll have to pull the oven out and take the top off to get at the latch,hope this helps
7/4/2020 5:47:20 PM • KitchenAid Ovens • Answered on Jul 04, 2020
I have a KitchenAid KOCE500ESS04 with a error F6 E8 contact MW AM. What could be the problem?
In our case, the error code was displayed on a KitchenAid microwave/oven combo. It turned out to be a $4 fuse called the "Main Cavity Fuse". Good luck.
3/4/2020 9:05:02 PM • KitchenAid Ovens • Answered on Mar 04, 2020
My Kitchen Aid Superba Oven
Hi, my name is Audrey. I am a KitchenAid employee and would appreciate the opportunity to assist you with your oven. Please send me an email through our customer service address,
[email protected] and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model and serial number, and I would be happy to try to help resolve the situation with your appliance.
8/7/2019 5:25:27 PM • KitchenAid Ovens • Answered on Aug 07, 2019
KitchenAid countertop oven,do they have a replaceable fuse? The power light doesn't come on. I replaced a fuse in a microwave once, so I thought maybe.......
Hello Susan Bailey, Typically "THEY" do... It would be really great to know if we are talking about a USA domestic product... or another NATIONALITY. Other countries normally have FUSES in the appliance cords. Find your MODEL NUMBER and go to a PART/SPARES supplier ( I like appliancepartspros.com ) -> appliancepartspros.com If this is a "MICROWAVE" the FUSE will start popping because the MAGNETRON has deteriorated and is CONSUMING it's own energy. I can be a LOT MORE specific if you provide a model number (pretty please). Read minds... Cannot rally do...!! https://en.wikipedia.org/wiki/Carnac_the_Magnificent
6/25/2019 7:09:13 PM • KitchenAid Ovens • Answered on Jun 25, 2019
My kitchen aid double oven has an error code f6e6 contact am1
Possible Solutions
Reset power to the product:
There may be a problem with the Oven Appliance Manger Control or the associated wiring.
  • Power unit down by turning off the circuit breaker(s) for one (1) minute.
  • Power unit up by turning on the circuit breaker(s).
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify oven operation.
Still need help? Call or schedule service.
2/2/2019 8:27:16 PM • KitchenAid Ovens • Answered on Feb 02, 2019
Kitchenaid superba 9752834A
Yes
9/15/2018 5:46:59 AM • KitchenAid Ovens • Answered on Sep 15, 2018
I have a Kitchenaid Imperial 17" Double KEDO
the is an external fan which draws all the moisture away,pull oven out and follows the two wires frm the and make sure both are connected and connected so it is alive when oven is on, if good the probaly a faulty fan
7/15/2018 1:56:41 AM • KitchenAid Ovens • Answered on Jul 15, 2018
Clock will not reset on Kitchenaid Superba WEMS double oven - timer works, but no clock
KitchenAid KODE507ESS (this MAY be your model??)... you did not specify?... This link MAY have your DISPLAY PARTS: KitchenAid Range Stove Oven Display Board Anthony
7/9/2018 3:34:32 AM • KitchenAid Ovens • Answered on Jul 09, 2018
What does errer codes E6 and F2 on KitchenAid Superba oven mean
From the Site: "F2-E6 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly. All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD)." Kitchen Aid Appliance Fault Codes Hope this helps! Anthony
7/9/2018 2:52:39 AM • KitchenAid Ovens • Answered on Jul 09, 2018
KitchenAid Architect Series KEBC177KSS Electric Single Oven Logo
Popular Tags
7 questions posted
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Ovens
  • KitchenAid Ovens
Most Popular Question
kitchen aid
  • Ovens
